T-Max OUTBACK 12V 9000 lbs Winch problems
  • atnas666
22 Feb 2016 18:04 #162807 by atnas666
Hi guys has any one had experience with these?
Mine after 4 uses has stopped working..
Was winching at the time, stopped winch to check security, Then tried to carry on but nothing just click from the solenoid pack.
Any ideas?
Is there a way i can test to see if its motor or solenoid (its just over a month old)
Thanks in advance
  • wombat
22 Feb 2016 18:10 #162811 by wombat
Replied by wombat on topic T-Max OUTBACK 12V 9000 lbs Winch problems
Get back to the suppliers, will still be under warranty :)
  • atnas666
22 Feb 2016 18:13 #162812 by atnas666
Replied by atnas666 on topic T-Max OUTBACK 12V 9000 lbs Winch problems
wombat wrote: Get back to the suppliers, will still be under warranty :)
I will just wanted to know if there was a way to test it.
The other reason is coz i dont want the supplier thinking im mucking him about (jimnybits) As had a problem with his winch tray too and this was from the same order(resolved and very helpful)
  • Daniel30
22 Feb 2016 18:16 #162813 by Daniel30
Replied by Daniel30 on topic T-Max OUTBACK 12V 9000 lbs Winch problems
Did it stop when you was in that mud pit?
  • atnas666
22 Feb 2016 18:19 #162814 by atnas666
No up the big slope. an hour after mud pit
  • TomDK
22 Feb 2016 18:23 #162815 by TomDK
Replied by TomDK on topic T-Max OUTBACK 12V 9000 lbs Winch problems
atnas666 wrote: Hi guys has any one had experience with these?
Any ideas?
Thanks in advance
You can try something out yourself.
Put a positive lead directly on the A and either of the F terminals on the winch motor itself. And of course a negative lead on the Ground terminal. That way you can see if the winch motor still works or if it's just the solenoid.
Time to create page: 0.188 seconds
