second gear noise
31 Jan 2016 20:45 #161588 by Mike G
Replied by Mike G on topic second gear noise
Thanks Mick,
I'll definitely be changing the gear oil. Once I'm ready for a clutch change, I will take the gearbox off and get it sorted out. I'll take it easy shifting into second for the time being.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
31 Jan 2016 20:46 #161589 by mlines
Replied by mlines on topic Re:second gear noise
The gearboxes are pretty lumpy so it could well be "normal"
Where is the clutch "bite"? It could be that the cable needs adjusting.
Sent from my Nexus 5 using Tapatalk
31 Jan 2016 20:49 #161590 by Mike G
Martin,
The clutch bite is about 3/4 of the way up the pedal travel. All other gears are fine. I'll give that a try also.
I think I may need to rent a shed out to get the work done that I want. :lol: It's going to be cold for a while and more jobs like this keep appearing. :pinch:
31 Jan 2016 20:56 #161593 by Mike G
Just had a read of the manual. Will have a check of the distances mentioned in there for the clutch operation.
Thanks for all the assistance as usual, it's greatly appreciated.
Time to create page: 0.825 seconds
