Engine died and will not restart
  • micytrap
06 Aug 2015 19:13 #149239 by micytrap
Replied by micytrap on topic Engine died and will not restart
Thanks for your reply!
Fuel pressure at priming is 50psi give or take. I have recently replaced the pump in the tank as well as the pressure regulator on the fuel rail.
  • Chris d
06 Aug 2015 19:57 #149242 by Chris d
Replied by Chris d on topic Engine died and will not restart
Blocked fuel pipe is it getting fuel at the injectors that's a tough one
  • miniman899
09 Aug 2015 14:00 #149515 by miniman899
Replied by miniman899 on topic Engine died and will not restart
Have you checked the timing belt ?
  • micytrap
11 Aug 2015 11:51 #149635 by micytrap
OK, so an update-
Removed all of the tape covering the wiring harness and checked continuity of all of the wiring within, all checks good. Pins on ECU correspond with the service manual and have the correct voltage and earths. Replaced all fuses just in case and rechecked the relays for function. There is a relay taped to the wiring harness just above the fuse box under the dash - any idea what this is for?
Not sure what to do next.
  • mickt
11 Aug 2015 19:01 - 11 Aug 2015 19:02 #149650 by mickt
Replied by mickt on topic Engine died and will not restart
What are the colour codes of the wires? Using that you might be able to pinpoint what the relay is for.
Try putting the original ecu back in.
Last edit: 11 Aug 2015 19:02 by mickt. Reason: further info added
  • Al.
18 Aug 2015 17:22 #150072 by Al.
Replied by Al. on topic Engine died and will not restart
Any update on your problems.
Time to create page: 0.218 seconds
