where do I get wheels bearings ???????
- Thank you received: 923
01 Aug 2015 14:05 #148808
Replied by X8GGY on topic where do I get wheels bearings ???????
I've got a pair of the JimnyBits ones sitting on my spares shelf if you want them, and I'll replace them when they or BigJimny have stock back in...?
They are £39.60 each, plus £4.40 Signed-For first class if you want them? So that's £83.60 delivered
Dave, sat in a post office so they can ship immediately... well Postie will collect Monday morning...
01 Aug 2015 15:19 #148822
by Busta
My mistake, for some reason I was talking about kingpin bearings! Ignore me.
Replied by Busta on topic where do I get wheels bearings ???????
facade wrote:
Busta wrote: Visit your local bearing supplier! There will be one not far from you. They are a standard bearing. They might have the seals too. If not, they can be bought online very cheaply.
The bearings are a 30302 (15x42x14.3mm taper roller bearing)
They don't fit the front hubs, unless yours is special.
The front hub bearing is a single cassette type, with a split centre race. When you tighten the nut, the split closes and preloads the brearing. There is no way to adjust a pair of taper bearings, unless there is a crush spacer between them.
Look for 41X68X40/35 bearing. (I won't swear that is correct, as it is the same part as a vitara)
Loads on eBay. A bearing supplier can likely order them.
01 Aug 2015 16:55 #148836
by facade
Replied by facade on topic where do I get wheels bearings ???????
I see, I thought you were describing the pairs of taper bearings that some suppliers reckon will fit the hub, but won't as there are no spacers to keep them apart. :S
Cheers anyway
Cheers anyway
01 Aug 2015 20:07 #148849
by Busta
But on the subject of wheel bearings, I got mine from my local motor factors. No problems there!
03 Aug 2015 19:19 - 03 Aug 2015 19:20 #148961
Replied by mlines on topic where do I get wheels bearings ???????
Last edit: 03 Aug 2015 19:20 by mlines.
- miniman899
09 Aug 2015 14:06 #149516
by miniman899
Replied by miniman899 on topic where do I get wheels bearings ???????
Thanks for replys people got some off here as came back in stock turned up super fast orderd Thursday morning got them friday all fittes very happy
Time to create page: 0.144 seconds
