where do I get wheels bearings ???????
- miniman899
31 Jul 2015 17:18 #148775
by miniman899
where do I get wheels bearings ??????? was created by miniman899
Hi people
everywhere seems to be sold out where do people get there front wheel bearings . I dont want the cheap nasty ones that are tapered they last 5 minute's .
cheers
tom
cheers
tom
31 Jul 2015 18:00 - 31 Jul 2015 18:21 #148777
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic where do I get wheels bearings ???????
Have you tried the Big Jimny shop?? Edit, I see there out of stock too.
Last edit: 31 Jul 2015 18:21 by Jezz. Reason: Editing
- mickt
31 Jul 2015 19:47 #148782
by mickt
Replied by mickt on topic where do I get wheels bearings ???????
Try this supplier They have them in stock at £24.95 each.
www.febest.eu
Superb service and quality item. I have had a few bits from them and they are cheaper than here. Good transit time too!
www.febest.eu
01 Aug 2015 08:37 #148791
by Busta
Replied by Busta on topic where do I get wheels bearings ???????
Visit your local bearing supplier! There will be one not far from you. They are a standard bearing. They might have the seals too. If not, they can be bought online very cheaply.
The bearings are a 30302 (15x42x14.3mm taper roller bearing)
These are the driveshaft seals: www.bearingshopuk.co.uk/os26x38x7mm-r23-...9wYf3zqBqBoC4QXw_wcB
- Basketcase
- Thank you received: 51
01 Aug 2015 08:47 #148792
by Basketcase
Replied by Basketcase on topic where do I get wheels bearings ???????
I got mine from Jimny bits, they seem alright up to now easy to fit as well
01 Aug 2015 11:27 #148800
by facade
They don't fit the front hubs, unless yours is special.
The front hub bearing is a single cassette type, with a split centre race. When you tighten the nut, the split closes and preloads the brearing. There is no way to adjust a pair of taper bearings, unless there is a crush spacer between them.
Look for 41X68X40/35 bearing. (I won't swear that is correct, as it is the same part as a vitara)
Loads on eBay. A bearing supplier can likely order them.
Replied by facade on topic where do I get wheels bearings ???????
Busta wrote: Visit your local bearing supplier! There will be one not far from you. They are a standard bearing. They might have the seals too. If not, they can be bought online very cheaply.
Time to create page: 0.531 seconds
