Flexible exhaust joint seal?
26 May 2015 18:47 #144858
Flexible exhaust joint seal? was created by mlines
Has anyone got any tips on how to get the centre flexible exhaust joint (the one with springs) to seal.
it has a new stainless steel sealing ring installed but will not stop blowing from the joint.
- gus2000
26 May 2015 19:40 #144862
by gus2000
Replied by gus2000 on topic Flexible exhaust joint seal?
Hello Martin, I will apply more than five years ago LOCTITE 5920 and have had no problems since then
Gustavo
Gustavo
- mickt
27 May 2015 11:57 #144880
by mickt
Replied by mickt on topic Flexible exhaust joint seal?
Did you apply the gasket paste when assembling? White stuff in a tube that hardens when hot.
27 May 2015 12:43 #144883
Replied by mlines on topic Re:Flexible exhaust joint seal?
No, I did not apply any seal at all. The joint is spring loaded and designed to move so as far as I can see any sealant would crumble away?
Sent from my Nexus 5 using Tapatalk
- gaz3359
27 May 2015 13:28 #144884
by gaz3359
Replied by gaz3359 on topic Flexible exhaust joint seal?
Use black silicone sealant smells for the first ten mins then goes away,havnt used exhaust paste for years as its crap.
27 May 2015 14:07 #144886
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Flexible exhaust joint seal?
I've never used sealant in those, They normally blow for a bit then coke up and seal.
Time to create page: 2.985 seconds
