suzuki service
  • gusthegorilla
25 May 2015 20:10 #144812 by gusthegorilla
Replied by gusthegorilla on topic suzuki service
Dan, I forgot to mention....if you're gonna do your gearbox oil you'll need a massive syringe and about a meter of plastic tube...the filler plug is tight up against the underside, real difficult to get at. Battery powered oil pump is an alternative but unless you're gonna use it lots it's expensive.
  • Daniel30
25 May 2015 20:20 #144813 by Daniel30
Replied by Daniel30 on topic suzuki service
Thanks for the info Chris do you know how much oil goes in the gearbox?
25 May 2015 21:51 #144819 by Busta
Replied by Busta on topic suzuki service
Make sure you can undo the fill plugs before draining the oil to!
You can fill the gearbox quite easily with the 1l oil bottles with the little extension tubes. Push them up in between the gearbox and body, get the tube in the filler and squeeze the oil out. You can't empty the bottle completely, but if you get 2 bottles, squeeze in as much as you can from each then pour the leftover oil from one to the other and squeeze that in aswell you will get just enough to fill it, which is 1.7l from memory.
  • wombat
25 May 2015 21:56 #144820 by wombat
Replied by wombat on topic suzuki service
find a longer bit of tube, place it in the filler hole and route the tube up into the engine bay. You can then use a funnel or cut the bottom off your gear oil container and use that :) :)
25 May 2015 22:23 #144824 by Busta
The other advantage of being able to squeeze the bottles is you don't have to wait a week for to flow through a small bit of tube!
  • Daniel30
26 May 2015 05:18 #144829 by Daniel30
Thanks for the info guys any recommendations on what oil to use? Cheers
Time to create page: 0.350 seconds
