suzuki service
  • Daniel30
22 May 2015 07:18 #144624 by Daniel30
suzuki service was created by Daniel30
If I have a full suzuki service would they have changed gearbox and diff oil at some point on an 07 plate? Doesn't really state anything in the service book
  • markyp2000
22 May 2015 19:10 #144681 by markyp2000
Replied by markyp2000 on topic suzuki service
Best thing to do is phone the servicing dealer and see when its changed
  • Daniel30
22 May 2015 19:46 #144687 by Daniel30
Replied by Daniel30 on topic suzuki service
Cheers Mark I'll give them a call
  • rs200boy
25 May 2015 18:38 #144800 by rs200boy
Replied by rs200boy on topic suzuki service
In theory yes it should have been done but I've had a few in that have been to dealers all there services and went to drain and level plugs and you can tell they ve never been out Would probably suggest to get it changed separately and you will know it's been done
  • Daniel30
25 May 2015 19:42 #144806 by Daniel30
rs200boy wrote: In theory yes it should have been done but I've had a few in that have been to dealers all there services and went to drain and level plugs and you can tell they ve never been out Would probably suggest to get it changed separately and you will know it's been done
Yeah your right I need to change it then I'll know going to give it a go myself what tool do I need for the drain and fill plug do you know cheers
  • gusthegorilla
25 May 2015 19:58 #144809 by gusthegorilla
Replied by gusthegorilla on topic suzuki service
10mm drain plug tool by Draper is the one you want...don't be tempted to use a 3/8 drive ratchet which is 9.5mm....you'll strip out the recess.
Soak them in PlusGas releasing fluid for a day first.
Chris.
