Power loss puzzle
19 Feb 2015 00:11 #138388
by facade
Replied by facade on topic Power loss puzzle
A stuck EGR valve should put the EML on, as the engine tests it at idle by tweaking it and seeing if the revs change, but worth cleaning it anyway.
A dodgy crank sensor usually doesn't put the EML on, you would expect it to, but plenty of people say it doesn't.
The crank sensor is under the alternator, and is much more likely to fail than the cam sensor, as 1) it is more expensive, and 2) harder to change
19 Feb 2015 08:27 #138397
by Halford
interesting, so it only checks at idle, :huh:
and at idle it looks OK, else the engine would be stumbling and may even stall
however, If the EGR is on during acceleration, low power (from reduced air/fuel volume) could be giving these issues
Facade know so much more about stuff than me so follow his advice and try the crank sensor first
good luck, keep us posted
Replied by Halford on topic Power loss puzzle
facade wrote: A stuck EGR valve should put the EML on, as the engine tests it at idle by tweaking it and seeing if the revs change, but worth cleaning it anyway.
19 Feb 2015 20:57 #138529
by Rhinoman
No it checks the electrical circuit at key on and also checks the function during deceleration when it flicks it on again very briefly and checks for a change in manifold pressure.
The crank sensor is much more likely but its always worth cleaning the EGR and its passageways because a reduction in EGR flow will reduce part throttle efficiency because it will reduce the effective compression ratio.
Replied by Rhinoman on topic Power loss puzzle
Halford wrote: interesting, so it only checks at idle, :huh:
- mc_nebula
19 Feb 2015 22:22 #138544
by mc_nebula
Replied by mc_nebula on topic Power loss puzzle
I just had a simillar problem with my Jimny which was fixed today. I took the car to my friend who is a mechanic. Like you, he found no fault codes. He did some digging on the car and found a wire on the wiring loom had become damaged and was shorting out, basicly causing the car to run on 2 cylinders.
He seemed to think that as the jimny only has a crank sensor an not a cam sensor to fall back on, the engine simply wouldn't run if that was the issue?
Ali.
Ali.
- pam
20 Feb 2015 19:45 #138614
by pam
Replied by pam on topic Power loss puzzle
The new crankshaft sensor didnt work...
At its worst tonight i pulled over and looked at every area i could think of and got under the car not just in the engine.
The 'cat' is glowing bright red! :ohmy: :sick:
- troggy
20 Feb 2015 19:59 #138622
by troggy
Replied by troggy on topic Re:Power loss puzzle
My post looked pretty bad after you said it did not fix the problem.
I seriously meant it is a fantastic site!
Time to create page: 0.486 seconds
