alternator upgrade winch and battery
- Chazg83
03 Feb 2015 23:35 #136856
by Chazg83
Replied by Chazg83 on topic alternator upgrade winch and battery
I'm using bmw main power cables for my winch so should be good wire if bmw use them and they seem to be doing good
- TomDK
03 Feb 2015 23:41 - 03 Feb 2015 23:43 #136857
by TomDK
Has nothing to do with who uses them. No matter if it's BMW, Mercedes or Rolls Royce, the cables need to big enough to take the AMPs. And no starter motor draws as many amps as a winch motor.
35mm2 cable is decent for shorter distances, like battery under bonnet. But with battery the boot, no less than 50 mm2.
Your optima is 50 Ah, not 95.
Replied by TomDK on topic alternator upgrade winch and battery
Chazg83 wrote: I'm using bmw main power cables for my winch so should be good wire if bmw use them and they seem to be doing good
Last edit: 03 Feb 2015 23:43 by TomDK.
- TomDK
03 Feb 2015 23:45 #136858
by TomDK
50 mm2 cables would no doubt be the best choice. But if on a budget, you can do with 35 mm2.
Riceye46 wrote: It's a champion c8000ewx
- Riceye46
04 Feb 2015 00:11 #136859
by Riceye46
Replied by Riceye46 on topic alternator upgrade winch and battery
I'll get 50mm ones as I would like it to last would it be best to get that from a car audio place or a motor factors
- TomDK
04 Feb 2015 00:20 #136860
by TomDK
Cheapest option is probably getting them from a welding supplier
- Riceye46
04 Feb 2015 00:38 #136861
by Riceye46
Great I'll make some phone calls in the morning cheers
Time to create page: 0.182 seconds
