Changing a detachable towbar to a fixed one?
- Basketcase
- Thank you received: 51
09 Jan 2015 18:01 #134673
by Basketcase
Replied by Basketcase on topic Changing a detachable towbar to a fixed one?
That looks like the one I have and seems like the same size gap between the 2 plates but youre one step ahead as I have no name on the one I have at all, I got it off a trade Jimny at work with no electrics or ball part
- trextr7monkey
10 Jan 2015 19:59 #134750
by trextr7monkey
Replied by trextr7monkey on topic Changing a detachable towbar to a fixed one?
If you are thinking of changing it then it would be worth trying to sort the existing which has clearly been neglected. We bought a used one and had the same problem. You can download an exploded diagram and it is not difficult to see how it is meant to function. Penetrating oil a cup of tea then a whack with a rubber mallet should extract the towbar which if cleaned with some wet and dry paper then smeared with grease will make it very easy to atyach/remove.hth
MIKE
MIKE
- Thank you received: 1875
11 Jan 2015 06:57 #134784
That's like mine which is a witter detachable stowbar which is in turn a rebranded gdw from Belgium. I like mine because the two top holes where you clip the breakaway cable to happen to be wide enough apart to take the loop of my 7 tonne recovery strap and so with a trailer pin out of a tractor I have a rear tow point without needing the actual ball in place.
Replied by Lambert on topic Changing a detachable towbar to a fixed one?
Rhinoman wrote: I have the same problem as well but I hadn't been able to identify the towbar, mine looks like this:
- miktt100
11 Jan 2015 17:13 #134824
by miktt100
Replied by miktt100 on topic Changing a detachable towbar to a fixed one?
It's the same as mine I just fitted , it's from BTH just needs a bit of grease but good idea to be removable so I can use as a tow point
- Benn
23 Jan 2015 20:33 #135886
by Benn
Replied by Benn on topic Re:Changing a detachable towbar to a fixed one?
Well unfortunately from my asking around it looks like you can't get a fixed neck to replace my detachable one as now the whole unit has to be type approved and rated, so it looks like I will be saving up for a new complete bar setup.
Has anyone else had any luck?
23 Jan 2015 21:40 #135893
When I was having trouble with the towbar on dad's terios I was on the phone to a senior technical bod at witter, what he was saying was that they make the fixed and detachable necks to a uniform size to save on manufacturing costs and to allow the same neck to be used on a selection of different vehicles as the designs allow the only specific bit being the actual bar that bolts to the car. What that means is that the same bar has type approval for the vehicle with either neck. Allegedly. This all sounds plausible but could just as easily be the bloke at witter telling me what he thought I wanted to hear to get rid of me asking awkward questions.
Time to create page: 2.899 seconds
