Changing a detachable towbar to a fixed one?
  • Benn
07 Jan 2015 20:29 #134478 by Benn
Hi all,
My Jimny came with a brink detachable towbar that got wedged in the first time I tried to fit it, and so in the end or remove it I ended up unbolting the mounting with neck and bar still attached. That means that all I am now left with is the main mount, so I was wondering if it is possible to get a fixed neck that I can just bolt in to this mount.
It looks like this... and the gap between the two vertical mounting plates is approx 57mm.
Any help or advice would be very welcome.
Cheers
Ben
Sent from my iPad using Tapatalk
  • rayz_x
07 Jan 2015 21:57 #134486 by rayz_x
Towtrust bars make them quite like that
www.towbars-uk.co.uk/images/default/towtrust_swan_large.jpg
I got mine from Norbrook/Towbars Direct who were very helpful -
www.towbarsdirect.co.uk/intro.htm
Ray
08 Jan 2015 12:41 #134523 by Rhinoman
Brink make a swan-neck, I don't know if its available seperately.
  • Benn
08 Jan 2015 13:04 #134525 by Benn
Thanks for the advice. I will try towbars direct and see how I get on.
08 Jan 2015 17:41 #134558 by Basketcase
Keep posted on how you get on! I have one of these toward without the ball/swan neck part that fits into the block that goes onto the bar( that'll be the part you removed that got wedged together)
08 Jan 2015 21:18 #134596 by Rhinoman
I have the same problem as well but I hadn't been able to identify the towbar, mine looks like this:
Time to create page: 1.751 seconds
