idle rpm how to speed up
  • richie rich
28 Nov 2014 17:26 #130833 by richie rich
idle rpm how to speed up was created by richie rich
hi with winter here i was wondering if i could speed up my tickover to cope wiry constant electrical load all the time
  • jb33w
07 Dec 2014 18:02 #131765 by jb33w
Replied by jb33w on topic idle rpm how to speed up
you could probably adjust it by playing with IAC valve part with coils. The IAC itself consists of 2 parts, the one with metal pipes and holes for intake air and the one with coils that control the valve rotor (it's a black plastic thing). Loosen the screws holding the latter and set desired idle rpms.
07 Dec 2014 18:33 #131768 by Rhinoman
Replied by Rhinoman on topic idle rpm how to speed up
The ECU will always try to correct the idle speed, if you try to cheat it then it will go into a fail-safe mode.
07 Dec 2014 19:08 #131771 by j999pre
Replied by j999pre on topic idle rpm how to speed up
You could fit a hand throttle cable to the throttle body just open it a tad. Or adjust the throttle cable retaining nuts duo that the butterfly is just open a bit
Grey pick up Jimny
  • Rockwatt
08 Dec 2014 07:57 #131808 by Rockwatt
Replied by Rockwatt on topic idle rpm how to speed up
Throttle body bypass is the only reliable way, run a small hose 6mm id ish from just before the throttle body to just after with a valve in the hose to control it.
08 Dec 2014 12:02 #131828 by facade
Replied by facade on topic idle rpm how to speed up
As Rhinoman says, provided the throttle is closed, as reported by the position sensor, the ecu will try and correct anything that you do, and throw a paddy if it can't.
You need to tickle the throttle to tell the ecu that it is an operator demand, and then it won't be very stable.
As J99pre suggests, an auxiliary fast idle cable like in The Olden Days is the best idea. (My 1993 Terrano diesel had one, just like a choke cable, it would do 50 in top gear with it fully out)
