Factory Jimny Coil dimensions?
  • jwriebe
29 Sep 2014 12:46 #125377 by jwriebe
Factory Jimny Coil dimensions? was created by jwriebe
Hello,
Admittedly, I'd rather not tear my Jimny apart as it gets me to work 6 days out of the week B) so I have a question:
Anyone have the measurements for factory Jimny springs, front and rear. Specifically: inner diameter and free length.
Off of my rough measuring with them on the car it seems the rears are around 175 lb springs and the fronts a might heavier...any thoughts?
Thanks,
Jon
  • TomDK
29 Sep 2014 17:39 #125400 by TomDK
Replied by TomDK on topic Factory Jimny Coil dimensions?
You want to know standard jimny coil rates?
Front and rear springs on petrol jimny are all 120 lbs/in
Front springs on diesel jimny are 150 lbs/in
More info here:
www.arbusa.com/Uploads/PDF/onlineManuals...ME_Guide_current.pdf Page 74 and 133
  • gus2000
29 Sep 2014 21:47 #125426 by gus2000
Replied by gus2000 on topic Factory Jimny Coil dimensions?
Hello, my jimny coil dimensions (factory).
Measured on these
K is calculated by adecuate equation
Also, k is calculate with 1.5 turns less because it is supported on the plates
8 mm less for the intensive use
  • TomDK
29 Sep 2014 21:55 #125427 by TomDK
gus2000 wrote: Hello, my jimny coil dimensions (factory).
Measured on these
There's something wrong with those calculations. it takes a good deal more than just 20-24 kg's to reduced the springs length by 1 cm. Look in the PDF file i've linked to above, it shows the correct springs rates.
  • jwriebe
30 Sep 2014 00:12 #125432 by jwriebe
Replied by jwriebe on topic Factory Jimny Coil dimensions?
Gentlemen,
I really appreciate all the information. It really simplifies my ability to select an aftermarket spring!
Thanks for the input!
Jon
  • gus2000
30 Sep 2014 01:21 #125434 by gus2000
TomDK wrote: There's something wrong with those calculations. it takes a good deal more than just 20-24 kg's to reduced the springs length by 1 cm. Look in the PDF file i've linked to above, it shows the correct springs rates.
Yes Tom, Quite so! :)
26 N/mm
1N = 0,102 Kg :)
1mm = 0,1 cm
Conversion coefficient is very close to 1 (practically 1N/mm = 1 Kg/cm)
I think that my calculation is correct .
Time to create page: 0.864 seconds
