Rattle on acceleration
  • Jimnychris
16 Jun 2014 21:43 - 16 Jun 2014 22:06 #118033 by Jimnychris
Rattle on acceleration was created by Jimnychris
Hi there, I`m new to this site, so I hope I`m posting in the correct section? Anyway, I have a strange rattle noise when I accelerate in every gear accept 5th and reverse :( the noise is NOT there when the jimny is parked and engine is revved, I thought it was coming from the transfer box so I fitted another one but it wasn't that :( All the UJ`s are fine, there`s no heat shields so its not that, the internals of the cat are fine as well, I drained the oil from the gearbox and that was clean (no bits in it) but there was a shard of silver metal stuck to the drain plug magnet, so I have taken the gearbox off the car and opened it up expecting to see a broken or worn bearing or broken or worn teeth but everything looks in mint condition and all turns and moves as it should with no noises or vibrations, I've taken off the clutch and it needs replacing (scratched and worn) but I cant see that making the noise? the thrust release bearing is as it should be as well? Its proper got me has this :( has anyone else here had anything similar, or got any ideas? thanks (VVT 2005 hardtop)
Last edit: 16 Jun 2014 22:06 by Jimnychris. Reason: more info
16 Jun 2014 21:54 #118035 by Busta
Replied by Busta on topic Rattle on acceleration
Wow! That's some pretty comprehensive investigating! Mine does the same, but only in 1st and 2nd at high revs. I wondered if it was a gearbox mount but I haven't looked yet.
You've ruled out most of the major things so it can't be anything too bad!
  • Jimnychris
16 Jun 2014 22:03 #118041 by Jimnychris
Replied by Jimnychris on topic Rattle on acceleration
The only thing I can do now is put a new clutch kit on and put it all back together again :( If the noise is still there all I can do is drive it till something breaks? I`m ready for burning it :) haha
  • Millzy
17 Jun 2014 04:55 #118055 by Millzy
Replied by Millzy on topic Rattle on acceleration
Question mate do you have transfer box guard on your car I have one on mine and since I did I had rattled in 1st taking of and some times second taking off so could be that if you have one that is
  • Jimnychris
17 Jun 2014 07:23 - 17 Jun 2014 10:09 #118058 by Jimnychris
Ye, i have a transferbox guard but the rattle is there with the guard off aswell, all the transferbox mounts are good aswell as the transferbox bushes, i'm going to give it a good going over again today before it all goes back together, fingers crossed i find something?
Last edit: 17 Jun 2014 10:09 by Jimnychris. Reason: More info
17 Jun 2014 12:39 #118068 by Casey
Replied by Casey on topic Rattle on acceleration
Like Busta mine has the rattle in 1st and 2nd, particularly when starting away. I've also noticed that there is a judder if I start away with the steering turned, but like Busta, haven't got round to checking the gear box mounts yet.
Time to create page: 2.432 seconds
