Anti-roll bar - keep or remove
  • jtayl153
11 May 2014 16:10 #114847 by jtayl153
Anti-roll bar - keep or remove was created by jtayl153
Hi all.
I've read that people have removed their anti roll bar and Im curious as to why someone would?
What are the benefits?
What are the drawbacks??
  • jonesyba420
11 May 2014 16:25 #114848 by jonesyba420
Replied by jonesyba420 on topic Anti-roll bar - keep or remove
Pros: More articulation, smoother less crashy ride.
Cons: slightly more body roll.
Take it off you wont regret it in my opinion.
Beware tho if you have a suspension lift you will need extended brake lines.
  • jtayl153
11 May 2014 16:33 #114850 by jtayl153
Replied by jtayl153 on topic Anti-roll bar - keep or remove
I only have 40mm lift. I'll def need extended brake lines?
  • Bigjim91
11 May 2014 16:34 #114852 by Bigjim91
Replied by Bigjim91 on topic Anti-roll bar - keep or remove
Do it, you won't regret it!
  • jtayl153
11 May 2014 16:36 #114853 by jtayl153
Oh right of course. Its 230am here, brain just got into gear!
No ARB = More Articulation = more distance between wheel and brake fluid = need longer lines otherwise risk snapping standard lines if fully flexed.
right?
  • mc_nebula
11 May 2014 17:03 - 11 May 2014 17:04 #114857 by mc_nebula
Replied by mc_nebula on topic Anti-roll bar - keep or remove
Bang on mate. I've had mine off for ages, it rolls around a little more but not a massive amount, and the articulation is supposedly greater, though I've never seen any comparison photos/figures...
Be aware though - the MOT becomes a point of contention.
I'm not a tester, nor am I in the trade, however I am lead to believe that a missing anti-roll bar is an MOT failure.
If you un-bolt all the mounting brackets and droplinks, unless the tester is a jimny expert they are unlikely to realise it should have one.
[edit, just realised you aren't in the UK, so ignore the MOT stuff, that's UK specific.]
Last edit: 11 May 2014 17:04 by mc_nebula.
Time to create page: 0.394 seconds
