King Pin Bearing?
  • jonesyba420
26 Mar 2014 14:28 #110143 by jonesyba420
Replied by jonesyba420 on topic King Pin Bearing?
:laugh: :laugh: :laugh:
The list goes on.............something to catch the gloop in that you dont mind throwing away................a swear jar because lets face it its f*$#%*g discusting and there WILL be stubborn nuts and bolts ;)
26 Mar 2014 18:48 #110173 by facade
Replied by facade on topic King Pin Bearing?
Back to stuff to buy:
Spare nylock nuts for the ball joints on the end of the track rods. They are the same thread as wheelnuts M12x1.25 if original
When I did mine I wirebrushed the exposed threads on the track rod end joint nuts, then made a thread cleaner ( out of an old wheelnut by filing a couple of grooves along the thread) and screwed that down to the nut.
Still when I undid them, they got about halfway and the taper came undone so the nut will not come undone.
I had to split the nuts to get them off to remove the hub.
The following user(s) said Thank You: The Dug
  • idiotmobil
26 Mar 2014 18:53 #110174 by idiotmobil
Replied by idiotmobil on topic King Pin Bearing?
windy gun on tapered rod ends ive never failed to undo them shocks them off, if no windy gun then hammer underneath and spanner undoing at same time usealy works pushes the tapper up tight
  • The Dug
27 Mar 2014 08:17 #110253 by The Dug
Replied by The Dug on topic King Pin Bearing?
Thanks for the advice folks, I'll get the M12 nuts ordered.
Replaced the rod ends recently so shouldn't be too much of a problem but better to have and not need eh?
27 Mar 2014 17:21 #110306 by facade
Don't just ask for M12, you will get coarse thread, ask for M12 x 1,25 fine pitch. They are about 50p each, and you only need 2.
You should change nylock nuts anyway as they are only supposed to work once. ;)
Time to create page: 0.278 seconds
