King Pin Bearing?
  • The Dug
23 Mar 2014 20:02 #109761 by The Dug
King Pin Bearing? was created by The Dug
Evening all,
With all my time rolling around underneath the Jimny recently I've noticed a few things transfer box mountings, brake pipes and this;
Having looked at other posts I'm fairly sure this means the King Pin Bearing needs replacing, couple of questions.
I'm going to be away for a few weeks but in that time both my wife and dad might need to use the Jim, is this likely to cause further problems or is it best to leave it stationary until I get back to fix it?
If I'm replacing the KPB should I look at replacing anything else while I've got the hub in bits?
  • 410shotgun
23 Mar 2014 20:11 #109766 by 410shotgun
Replied by 410shotgun on topic King Pin Bearing?
yes you need to do the 2 bearing and the seal
23 Mar 2014 20:17 #109768 by j999pre
Replied by j999pre on topic King Pin Bearing?
Yes top and bottom bearings and inner seal, maybe outer depending on condition
Grey pick up Jimny
The following user(s) said Thank You: The Dug
  • The Dug
25 Mar 2014 14:21 #110024 by The Dug
Replied by The Dug on topic King Pin Bearing?
Thanks for that,
So if I purchase the king pin bearing kit & the swivel seal from the shop that will be all I need?
That's assuming I don't find anything else wrong obviously.
  • idiotmobil
25 Mar 2014 17:01 #110033 by idiotmobil
Replied by idiotmobil on topic King Pin Bearing?
You dont need the out side seal for deffo its only a dust seal and wouldnt stop a leak I dont Change mine but I clean out my swivels regulary
  • 410shotgun
25 Mar 2014 18:33 #110039 by 410shotgun
you need 2 bearings a side and a oil seal that goes in the end of the axle on the drive shaft
that's 1 seal a side cost you around £30 for the 2 sides
Time to create page: 0.362 seconds
