Brake drum removal
  • markyp2000
09 Feb 2014 12:51 #103978 by markyp2000
Replied by markyp2000 on topic Brake drum removal
RichiesJimny wrote: If its the brake warning light that's coming on check the brake fluid level.
+1 also i would start by checking the front brakes first and if you dont know how to get the drum off you shouldnt be doing the job in the first place
09 Feb 2014 16:54 #103997 by mlines
Replied by mlines on topic Brake drum removal
  • Leathery1
12 Feb 2014 14:49 #104284 by Leathery1
Replied by Leathery1 on topic Brake drum removal
Markyp2000 I have replaced plenty of brakes in the past and not having done any for a while just wanted the tips people have for the Jimny as every one is slightly different. Never done one where the drum is wound off with bolts like this before, always used a puller or a big hammer! Discovered fluid level is down cos both front and back brakes are well worn, this is why the light is coming on.
  • GuardianAngel
12 Feb 2014 14:55 #104285 by GuardianAngel
Replied by GuardianAngel on topic Brake drum removal
Leathery1 wrote: Markyp2000 I have replaced plenty of brakes in the past and not having done any for a while just wanted the tips people have for the Jimny as every one is slightly different. Never done one where the drum is wound off with bolts like this before, always used a puller or a big hammer! Discovered fluid level is down cos both front and back brakes are well worn, this is why the light is coming on.
You can still use a hammer. Give it a tap all the way round and it will loosen so you can pull it off with your hands.
Time to create page: 1.143 seconds
