m13a EGR valve?
- CheeseSteakJimmys
08 Feb 2014 00:02 #103834
by CheeseSteakJimmys
Replied by CheeseSteakJimmys on topic m13a EGR valve?
I've tried uploaded the image twice and it keeps squashing it, i hope it's still readable for you
08 Feb 2014 16:51 #103896
by Rhinoman
Replied by Rhinoman on topic m13a EGR valve?
EGR actually has nothing to do with reburning gasses, the exhaust gas is considered inert. At part throttle the compression is much less and the restriction of the throttle causes pumping losses. The exhaust gas is injected into the manifold to make up space in the cylinder and reduce the pumping losses, the net effect is a higher effective compression, better combustion and higher efficiency. EGR is disabled at high loads so it has no effect on max. power. Overall its a good thing and as long as its cleaned out occasionally then it will be quite reliable
Most of what you will read on the net regarding EGR removal concerns diesel engines which are quite different because they usually always work at full throttle and vary the fuelling.
- jonesyba420
08 Feb 2014 21:57 #103915
by jonesyba420
Replied by jonesyba420 on topic m13a EGR valve?
I was not planning to remove it just take it off clean it out and refit it. Ive heard it could be the cause of my revs dropping at idle. Is it simple to take off and clean etc?looking at that diagram its on the back of the block, does anyone have a picture of it or a nice guide for me?
- gus2000
08 Feb 2014 22:55 #103924
by gus2000
Replied by gus2000 on topic m13a EGR valve?
Hello.
One function of the egr valve is to reduce NOx in the exhaust.
Here we use two methods to override this valve
In the g13bb engine
Method 1. Easy..
replace the seal tube with an blind gasket
in the blue oval is located the gasket
Method 2. more complex
Sealing the hole of the cylinder head where the exhaust gases flow.
The cylinder head without exhaust manifold
Aluminium plug homemade
Flare the hole
Insert the plug
To cancel the damaged EGR prevents the intake manifold is full of waste gases and accelerate the engine to lose power until they are cleared waste gases
I believe it will be useful
Gustavo
In the g13bb engine
Method 1. Easy..
Flare the hole
Insert the plug
Gustavo
- TomDK
08 Feb 2014 22:58 - 08 Feb 2014 23:00 #103925
by TomDK
Replied by TomDK on topic m13a EGR valve?
Thanks Gus.
One question.
What is the red circle in the first photo for?
One question.
Last edit: 08 Feb 2014 23:00 by TomDK.
- jonesyba420
08 Feb 2014 23:49 #103928
by jonesyba420
Id already found that but I dont need to block it off jist want to clean it out and its the wrong engine lol. Some people are saying remove it others are saying best to leave as its needed and just clean it. Im not to sure why you would want to overide it as its obviously got a purpose?
