Instrument Cluster lights
  • markyp2000
23 Jan 2014 16:24 #101708 by markyp2000
Replied by markyp2000 on topic Instrument Cluster lights
Havnt got a clue mind dont buzz its ither next to the fues box or behind the cluster
yep them the screws just give it a good putt as there are clips all the way round
  • jonesyba420
23 Jan 2014 16:30 #101709 by jonesyba420
Replied by jonesyba420 on topic Instrument Cluster lights
what did you do to stop the beeping lol, does my head in?! dont want to cut the wires to the pin switch for the door as my alarm wont work then.
so once the black trim is removed whats next or is it obvious? pretty sure the buzzer is on the circuit board for the dials have looked everywhere else and cant find it anywhere obvious :(
23 Jan 2014 21:16 #101757 by kirkynut
Replied by kirkynut on topic Instrument Cluster lights
markyp2000 wrote: Easy job remove 2 screws from around the speedo trim give it a good pull then remove speedo unit a few screws then find the bulb thats blown probs a 501bulb then test and refit easy only take about 15mins
Easy when you know how then!!!
  • markyp2000
23 Jan 2014 21:48 #101762 by markyp2000
jonesyba420 wrote: what did you do to stop the beeping lol, does my head in?! dont want to cut the wires to the pin switch for the door as my alarm wont work then.
as i said once the trim is off remove a few screws to the cluster
  • markyp2000
23 Jan 2014 21:49 #101764 by markyp2000
lol some times
23 Jan 2014 22:22 - 23 Jan 2014 22:32 #101774 by KJS
Replied by KJS on topic Went to the beach this morning
I am sure l read on here somewhere that to stop the beeping it is a green wire going into a connector underneath the steering column. You just disconnect it and the beep is gone, link below.
www.4x4community.co.za/forum/showthread.php?t=64362 .
Last edit: 23 Jan 2014 22:32 by KJS. Reason: Updated the link
Time to create page: 0.430 seconds
