Instrument Cluster lights
- jonesyba420
23 Jan 2014 23:06 #101792
by jonesyba420
Do you need to remove any of the buttons or the ends off the heater controls? Just like to gain as much info as possible.
Replied by jonesyba420 on topic Instrument Cluster lights
markyp2000 wrote:
jonesyba420 wrote: what did you do to stop the beeping lol, does my head in?! dont want to cut the wires to the pin switch for the door as my alarm wont work then.
so once the black trim is removed whats next or is it obvious? pretty sure the buzzer is on the circuit board for the dials have looked everywhere else and cant find it anywhere obvious
as i said once the trim is off remove a few screws to the cluster
- markyp2000
24 Jan 2014 00:10 #101799
by markyp2000
Replied by markyp2000 on topic Instrument Cluster lights
Nope just to screws on the dash then 2 or 4 around the cluster if there was anything else id of said
- jonesyba420
24 Jan 2014 08:48 #101805
by jonesyba420
ok.
- jonesyba420
24 Jan 2014 14:58 #101831
by jonesyba420
Took the dash apart ( as easy as mark said ) removed the dials and pulled this out of the back of the instrument cluster:
No more beeping when I leave the door open with the keys in
Slight side effect tho............. I also have no beeping if I leave the headlights on and remove the key. Not to bothered about this as im not blind lol. Bulbs look straight forward to change.
Time to create page: 0.318 seconds
