Fan belt snapping
  • kx100
18 Nov 2013 12:51 #91853 by kx100
Fan belt snapping was created by kx100
We'll I'm on my 5th belt in 3month or so and it's really starting to annoy me as I can't really rely on the jimny incase it brakes :/ some of the belts are clean snaps and others are just shredded .i don't understand why it's happening as everything is turning Freely . On Friday I fitted a new belt and it snapd before I got a mile from home so I went home and fitted a new belt now it snapd agane last night it was a clean snap and now it's lying in a village miles from home :( seriously considering selling it for spares or repair had enough now :(
  • ritchie
18 Nov 2013 13:38 #91858 by ritchie
Replied by ritchie on topic Fan belt snapping
Staring to worry now that uve got the same but slightly worse problem. I was really hopin I had put mine on too tight. All try look into it further and keep you posted.
18 Nov 2013 13:41 - 18 Nov 2013 13:43 #91861 by gilburton
Replied by gilburton on topic Fan belt snapping
Something is seizing or out of alignment as belts don't just break or snap especially new ones.
I know it's difficult to check when hot but is everything free immediately after it breaks?
I'm thinking something is locking up when hot?
The shredding would also point to a partial lock up.
Thinking logically obviously the crank is ok so that leaves the other pulleys/idler?
If I remember correctly Jimnys used to have a problem with the crank pulley cush drive breaking up?
Is everything in alignment with no damage or wear to the pulleys?
Is the water level ok? Or is it overheating before it snaps?
Can you twist the belt about 45-90 degrees just using your finger and thumb after tensioning it up?
These are just general questions and not about the Jimny as I'm not sure what the belt drives on the early Jimny?
Alternator bearings??
I started off high and worked my way down ever since :-)
Last edit: 18 Nov 2013 13:43 by gilburton.
  • kx100
18 Nov 2013 16:39 #91889 by kx100
Replied by kx100 on topic Fan belt snapping
Yeah everything turns Freeley with no belt on but once I fit belt it dosnt turn ?? Yeah the temp rises and battery light comes on that's when I notice somthings wrong
  • GuardianAngel
18 Nov 2013 16:44 #91892 by GuardianAngel
Replied by GuardianAngel on topic Fan belt snapping
Could just a small burr on one of the drive pulleys. Would only need to be small to cut through the belt at high revs.
18 Nov 2013 16:51 #91898 by gilburton
try looping the belt round each pulley individually and pull on the belt by hand with some force and at the same time try to rotate it to see if something is jamming the pulley(s) under tension.
If you do each pulley in turn it should hopefully pinpoint if any single pulley or component has failed??
Time to create page: 0.143 seconds
