info rear shock bolts ?
- Thank you received: 923
05 Nov 2013 09:35 - 05 Nov 2013 09:37 #89459
Replied by X8GGY on topic info rear shock bolts ?
I put 10mm ones in mine, 12.9 HT steel... rather than have to drill them out...
They are +3" bodylift Vitara front bolts as it happens... :whistle:
Last edit: 05 Nov 2013 09:37 by X8GGY. Reason: Picture Added
- ne-crock
05 Nov 2013 09:55 #89463
by ne-crock
Replied by ne-crock on topic info rear shock bolts ?
so dave those bolts slide straight through and remove the need for drilling?
and i presume you stock them?
05 Nov 2013 10:07 #89464
Replied by mlines on topic info rear shock bolts ?
I am a bit confused here?
The "hours of drill out" refers to where the original mounts have sheared off and you have to drill through the remains of the original bolt. This is very common.
I think Dave is talking about where the bolts are intact and can be undone otherwise I cannot see how you get around the drilling out issue?
- Dunnin21
05 Nov 2013 10:17 #89467
by Dunnin21
Replied by Dunnin21 on topic info rear shock bolts ?
Mind are still intact, I'm doing this as a precaution. Just Easyer to carry a spare but and bolt. So in my case will there be much drilling needed with the bolt already removed
- ne-crock
05 Nov 2013 10:23 #89468
by ne-crock
you've confused me now martin,
i thought we were talking about drilling the mount to allow for a bolt and a nut to be used to hold the shock absorber/relocator, not removing the snapped bolt
mlines wrote: I am a bit confused here?
- TomDK
05 Nov 2013 11:09 #89475
by TomDK
Replied by TomDK on topic info rear shock bolts ?
If you doing this as a precaution, it only requires a few seconds of drilling with a standard drill bit
Time to create page: 0.581 seconds
