info rear shock bolts ?
- Dunnin21
04 Nov 2013 21:09 #89421
by Dunnin21
info rear shock bolts ? was created by Dunnin21
Hi all
Just a quick one, im going to drill out the rear lower shock mount bolts and replace with nut and bolt. Can anyone tell me the size and lenght of the bolt I will need. Thanks Andy
- reaper
04 Nov 2013 21:11 #89423
by reaper
Replied by reaper on topic info rear shock bolts ?
I used m12 x 170mm high tensile with nyloc nuts
- Dunnin21
04 Nov 2013 21:27 #89426
by Dunnin21
Replied by Dunnin21 on topic info rear shock bolts ?
Thats all I needed thanks
05 Nov 2013 04:49 #89436
by Halford
Replied by Halford on topic info rear shock bolts ?
High Tensile Bolts
M12 x 70mm METRIC FINE Bottom,
M12 x 60mm METRIC FINE Top
martin sells them for £3.50 the pair
see here
see here
05 Nov 2013 06:59 #89445
by kirkynut
That's standard length, you'll need longer for the bottom one if drilling it out.
Perhaps get some studding and put nyloc nuts on both ends. You can cut to just the right length then.
Replied by kirkynut on topic info rear shock bolts ?
Halford wrote: High Tensile Bolts
see here
- ritchie
05 Nov 2013 07:41 #89450
by ritchie
Replied by ritchie on topic info rear shock bolts ?
Id recommend that you spend a bit more money on a really good set of drills before you start. And cover it with cutting combound when drilling. Both my bolts had sheard and it took me about 35mins with a good 12mm drill and installed like stated already 170mm long (B7) high tensile bolt with nylock nuts. I've read on hear some people took hours to drill them out. so good drills is the key.
Time to create page: 0.927 seconds
