vitara engine in jimny
  • Cider
31 Aug 2013 12:22 #81681 by Cider
Replied by Cider on topic vitara engine in jimny
I Think The crank sensor will be your main problem Unless it`s a Grand Vitara engine you`re going to fit.
As I`m sure the standard vits don`t have one
  • idiotmobil
31 Aug 2013 12:43 #81685 by idiotmobil
Replied by idiotmobil on topic vitara engine in jimny
it was a vitara engine we was looking at but think it would have to be a grand vit im still undecided weather to go ahead it seams a good idea as its going to cost me nothing just worried in the process of doing it im going to hit trouble I could do with out, I mite sort out getting a motor modding it to fit get it in his jimny running fine then once im happy swap them over its more work but then I have no worrys
  • idiotmobil
31 Aug 2013 12:57 #81687 by idiotmobil
do they do a grand vitara engine with same cam in is so be simple if I found one of them
  • Cider
31 Aug 2013 14:55 #81694 by Cider
idiotmobil wrote: do they do a grand vitara engine with same cam in is so be simple if I found one of them
The 1.6 Grand Vitara uses the same head as the jimny But it has a 11 lobed cam sensor ring same as a hard top
you can swop the cam from your soft top"2 lobed sensor ring"
  • Dave cc
31 Aug 2013 15:40 #81696 by Dave cc
Replied by Dave cc on topic vitara engine in jimny
Just swap the jimny head on the vitara block valves are only 1mm smaller will be job done for the price of head gasket ive put jimny heads on 8V vitara blocks with some little piston mods all very very easy to swap
  • Cider
31 Aug 2013 16:54 #81709 by Cider
Not sure how you can over come the soft top crank shaft sensor as the ecu will need it
unless it`s possible to transfer the sensor ring to the vitara engine or swop ecu :unsure:
Time to create page: 0.199 seconds
