vitara engine in jimny
  • Dave cc
31 Aug 2013 17:18 #81716 by Dave cc
Replied by Dave cc on topic vitara engine in jimny
Cider wrote: Not sure how you can over come the soft top crank shaft sensor as the ecu will need it
unless it`s possible to transfer the sensor ring to the vitara engine or swop ecu :unsure:
Good point do all the soft top have 2 sensors ??? weird why there is a diffrence i know my hardtop only had the one
31 Aug 2013 18:02 #81721 by j999pre
Replied by j999pre on topic vitara engine in jimny
I've done hard top g13 into soft top a few times. Not too bad to do.
Very early upto w reg soft top engines don't have the crank sensor. X reg on seem to.
You can also "trim" the extra lobes off a hard top cam down to 2 and clock it to match the soft to cam.
Swap the bottom inner timing belt pulley, sump, and drill the oil pump for the crank sensor 18mm
Grey pick up Jimny
Time to create page: 0.121 seconds
