Max speed 100km/h and loosing power after 3000rpm
- adamatdraycott
19 Aug 2013 11:46 #80281
by adamatdraycott
Replied by adamatdraycott on topic Max speed 100km/h and loosing power after 3000rpm
Jimnys arent great speed machines... and i tend to feel its most comfortable at about 55mph
They are certainly sounding a bit loud at anything above 3.5k RPM
Mine is fully serviced annually, and recently had a new cat and exhaust to the back... so mine is about as clean and unrestricted as a Jimny is going to get.
To my calculations your 12ltrs per 100km works out to be 23.5MPG... which is low, and a standard car should be nearer 30mpg. However at normal motorway speeds Jimnys are thirsty, which is half the reason i stick to 55mph
- JivingDaddy
19 Aug 2013 12:40 #80292
by JivingDaddy
Replied by JivingDaddy on topic Max speed 100km/h and loosing power after 3000rpm
I'll go along with Adam on that, it'll happily trudge along at 55mph without complaining. After that things get a bit messy, noisy and thirsty (and bouncy). You buy a Jimny for the grin, certainly not for the performance and/or road handling.
On the lack of power tho', it should rev up freely and not run out of breath at 3K. It will be bloody thirsty, but it should keep on truckin'. Ooh, I feel a song coming on. Now where's those flared trousers and platform shoes?!
- JuanGuillie
19 Aug 2013 12:47 #80294
by JuanGuillie
Replied by JuanGuillie on topic Max speed 100km/h and loosing power after 3000rpm
Try also air-filter change, it will not cost you much because you can do it yourselve.
Hopefully the gearbox is not engaged in 4 high (take a look on your dashboard).
Normally the Jimny can do 120/130 km/h but then you will be high in rev's.
If i were you and as was adviced already, change oil's and give it a full maintenance, that will not do any harm.
Maybe a "little bit" on your budget, but then you're shure that this is taken care for.
Crankshaft sensor could also be the reason, better to change it also.
- JuanGuillie
19 Aug 2013 12:49 #80295
by JuanGuillie
If i were you and as was already adviced, change oil's and give it a full maintenance, that will not do any harm.
Maybe a "little attack" on your budget, but then you're shure that all this is taken care for.
Succes !
Succes !
- Nikola66661
20 Aug 2013 16:25 #80476
by Nikola66661
Replied by Nikola66661 on topic Max speed 100km/h and loosing power after 3000rpm
I know guys that Jimny is not for speeding but it is something wrong when I cant have max speed and power (up hills specially )
when I was talking about fuel it was city driving yesterday I went countryside to buy tyres motorway driving 150miles spent 28liter driving 100km/h (62 ml)
I tried to take of the catalytic me self but is welded and I will need to take of the half of the exhaust.
I went to mechanic and he told me that it is impossible to clean it he said that I need to buy a new one if I think that is the problem.
Can anybody tell me how I can clean it
P.S. I check the air filter and its new
- barnes
20 Aug 2013 16:28 #80478
by barnes
Replied by barnes on topic Max speed 100km/h and loosing power after 3000rpm
Also check the tension on the throttle cable ul find it on the throttle body
Time to create page: 0.307 seconds
