The king pin replacement scenario
mickt wrote: These shims then, are not standard fit, but a "fix" for a condition caused by modifying the vehicle for major off-roading fun. If that is the case then, as this car is for road use only, I suppose the shims are not needed?
Cheers mickt
I didn't bother with them. I've got slightly wide wheels. I get light shimmy at 45mph but it is just regular imbalance and not death wobble; I'll get the wheels properly balanced ASAP.
- markyp2000
mickt wrote: Whilst the freewheel hub is off I have noticed that there is not a lot of grease in it. Should there be and what sort of grease is it?
Cheers, Mickt
A light grease that isnt to thick other wise it wont work correctly
- mickt
FACADE- When you say I have the bearings in wrong way, which way are they in on yours? Looking at the axle with all the bits removed with the upper and lower bearings at 6 & 12 o'clock the lower one sits in the outer race and is lifted out into the axle cavity and the upper one goes into the upper outer race and if not held there would just fall out, on mine. Surely you are not suggesting they are fitted the other way round?
MARKYP2000-What sort of torque figure do you think is required for these bolts? Very tight would seem to be about right for me, just like the brake calliper retaining bolts. They are about the same thread size. What do you think?
Upon getting round to cleaning all the bits for refitment I found the upper bearing had broken up, one of the rollers fell in two whilst cleaning it! The "shim" fitted looked like a bodge as the inner circumference was not a perfect circle. More like it had been filed to fit! Me wonders if fitting that caused the bearing to give up the ghost!
Ah well, onward and upward!
mickt wrote: FACADE- When you say I have the bearings in wrong way, which way are they in on yours? Looking at the axle with all the bits removed with the upper and lower bearings at 6 & 12 o'clock the lower one sits in the outer race and is lifted out into the axle cavity and the upper one goes into the upper outer race and if not held there would just fall out, on mine. Surely you are not suggesting they are fitted the other way round?
:blink: :blink:
The one at 6 o'clock (lower) should fall out due to gravity if fitted correctly. The top one (12 o'clock) should still in th race on its own due to gravity
The shim fits where I have coloured in pink, this jams the inner race tighter into the bearing to increase the preload and [strike]make it wear out faster[/strike] provide more resistance to steering wobble.
Top or bottom kingpin, or a shim for both, makes no difference, except the top is easier to do.
- idiotmobil
sounds like your king pins are in wrongmickt wrote: GUARDIAN ANGEL-The four bolts holding the hub on to the bearing carrier are specialist bolts as they have a serrated portion just under the head to stop the spring washer rotating. So when you say replace with a higher grade where do you get these specialist bolt from? Or do you mean just use a bolt of the correct length/diameter not worrying about the serrated bit?
