SOHC engine belt change frequency and cost?
- Sandspider
03 Jun 2013 13:20 - 03 Jun 2013 14:42 #72590
by Sandspider
SOHC engine belt change frequency and cost? was created by Sandspider
Hi all
I did search, but couldn't find anything.
With the SOHC engine, how often (mileage / time) should the cam belt be changed? Is this an easy(ish) DIY job, or a right pain without proper equipment? What sort of amount would it cost to get this done at a garage? Also, a full service?
I'm looking at a SOHC Jimny to possibly buy, but it hasn't had a cam belt change since 2007 and it's due a service so I'm wondering roughly how much to budget... (I'd do the service myself if at all possible, but just wondering what it would be likely to cost at a garage...)
Thanks.
Thanks.
Last edit: 03 Jun 2013 14:42 by Sandspider.
- Thank you received: 115
03 Jun 2013 14:09 - 03 Jun 2013 14:10 #72595
by maverick
Jalapeño, IISY?
Replied by maverick on topic SOHC engine belt change frequency and cost?
If in any doubt - i would change it ...
Normally it's every 50-60,000 miles - but it was the first thing i did when i bought my Jimny.
It's a relatively simple job to do yourself - just remember NOT TO MOVE engine or car with it in-gear whilst cam belt is off!!
Jalapeño, IISY?
Last edit: 03 Jun 2013 14:10 by maverick.
The following user(s) said Thank You: Sandspider
- vitara_mad
03 Jun 2013 14:40 #72597
by vitara_mad
Replied by vitara_mad on topic SOHC engine belt change frequency and cost?
for what it costs for a belt kit its worth doing & also worth changing water pump while you got the belt off
- markyp2000
03 Jun 2013 15:01 - 03 Jun 2013 15:05 #72598
by markyp2000
Replied by markyp2000 on topic SOHC engine belt change frequency and cost?
The cam belt dont run the water pump if its not leaking or over heating leave it
Up to 08/99 every 60000 miles or 5 years
After 09/99 every 54000 miles or 6 years
Book time is 2 hours
Last edit: 03 Jun 2013 15:05 by markyp2000.
- Sandspider
03 Jun 2013 15:44 #72600
by Sandspider
Replied by Sandspider on topic SOHC engine belt change frequency and cost?
Thanks all.
So knocking maybe £100 - £200 off the price to allow for belt change and service should be about fair...?
- vitara_mad
03 Jun 2013 18:52 #72621
by vitara_mad
I never said it did run the pump but the thing is you have to remove the cam belt to replace the pump so in my opinion its worth replaceing while the belt is off as they are not expensive but each to there own I suppose
markyp2000 wrote: The cam belt dont run the water pump if its not leaking or over heating leave it
