Bits4Vits transfer box mounts - any good?
  • RichiesJimny
07 May 2013 16:30 - 07 May 2013 16:55 #70212 by RichiesJimny
Replied by RichiesJimny on topic Re: Bits4Vits transfer box mounts - any good?
GuardianAngel wrote: Apparently they are 15mm lower to reduce angle on the prop. My fear is that my new TB guard wont then fit. Going to need to do the math on this one!
I would replace the aluminium mounting brackets with the ora up rated steel transfer box mounts. The original alloy mounts arnt very strong, I broke one on my last off road trip but fortunately I'd I fitted a transfer box gaurd which ment I could get home with a broken transfer box mount.
Apparently landrover engine mounts fit the jimny transfer box mounts and are cheap.
Last edit: 07 May 2013 16:55 by RichiesJimny.
  • GuardianAngel
07 May 2013 17:26 #70218 by GuardianAngel
Replied by GuardianAngel on topic Re: Bits4Vits transfer box mounts - any good?
mudman wrote: iv got them and i give my jim serious abuse and not broke one and my ORA t-box guard fit perfect
I have taken a chance and ordered them. If your ORA guard fits then its likely my Jimny Bits one will too.
I can always shim the mounts with more washers if needed to raise the TB up a bit.
  • GuardianAngel
09 May 2013 20:37 #70365 by GuardianAngel
My mounts arrived today.
You can remove the rubbers to bring them down to the same height as the current stock mounts, which is what I have done (so you only need two of the three). However, I only managed to fit one of the three tonight :blush:
  • Bits4Vits
10 May 2013 08:21 #70396 by Bits4Vits
Replied by Bits4Vits on topic Re: Bits4Vits transfer box mounts - any good?
Morning ;)
These trailmaster transfer box mounts - like any other uprated mounts of this kind - should be fitted in sandwich fashion, like this -
Apologies for the sketch, but you get the idea...?
Dave
  • GuardianAngel
10 May 2013 08:50 #70397 by GuardianAngel
Replied by GuardianAngel on topic Re: Re: Bits4Vits transfer box mounts - any good?
Bits4Vits wrote: Morning ;)
Dave
Cheers for that. Good job I only managed to fit one!
10 May 2013 10:36 #70398 by maverick
Dave
Ooops . I didnt fit mine like that ... another job to do :(
Jalapeño, IISY?
Time to create page: 0.208 seconds
