Spartan locker strange noise
  • MaxS
11 Aug 2012 14:08 #45911 by MaxS
Replied by MaxS on topic Re: Spartan locker strange noise
I surly will, if i'll manage to find any usefull info, well in worse case scenerio, I have 2 options, i'll have to replace the rear deferential or the noise will disapear and i'll change the oil. ;)
  • MaxS
15 Aug 2012 15:34 #46221 by MaxS
update: well' so far so good. still makes some noises sometimes but it depends on my way of driving
  • MaxS
06 Aug 2013 16:27 #79203 by MaxS
Update, I got about 1.5mm of each washer (which came with the spartan locker kit) and everything works fine. the strange thing is that the lockright locker washers are 4mm thick and the spartan was 5mm thick (i measured the lockers and their dimentions are basically the same...
  • nordom
06 Nov 2013 11:57 #89593 by nordom
Replied by nordom on topic Re: Spartan locker strange noise
MaxS wrote: Update, I got about 1.5mm of each washer (which came with the spartan locker kit) and everything works fine. the strange thing is that the lockright locker washers are 4mm thick and the spartan was 5mm thick (i measured the lockers and their dimentions are basically the same...
so, are the spartan washers are now 1.5 mm thinnerm than were, or You've grinded them to be 1.5mm?
I've got a spartan in my jimny being installed and it doesn't even unlock now.
  • suzukivit 1
06 Nov 2013 12:45 #89596 by suzukivit 1
Replied by suzukivit 1 on topic Re: Spartan locker strange noise
the spartin lockers are louder that the lock rite i found the springs on the last 3 spartin lockers i fitted were much harder than the lock rite ones and they were much more harsh when un locking i cant remember what i done about washers tho on the jimny but i removed them from the rear of my vit when i built that.
  • nordom
07 Nov 2013 08:18 - 07 Nov 2013 08:21 #89747 by nordom
thanks, but this doesn't help me(
I've found only two different instances of installation for now of Spartan to jimny rear diffs. In this case, the spartan washers has been grinded, but i'm not sure, how. In second case, the factory jimny washers has been used, but somewhat a year after installation the locker has begun to malfunction.
Last edit: 07 Nov 2013 08:21 by nordom. Reason: grammar
Time to create page: 0.162 seconds
