Spartan locker strange noise
  • supergaz
07 Nov 2013 09:30 #89756 by supergaz
Replied by supergaz on topic Re: Spartan locker strange noise
When fitting my lockright 1510 I found the supplied washers were too thick for the jimny, so I used the original thinner washers.
It pops and bangs a bit now and then.
  • suzukivit 1
09 Nov 2013 20:27 #90140 by suzukivit 1
Replied by suzukivit 1 on topic Spartan locker strange noise
ok been thinking about this and I removed the std side gear washers on the 2 jimnys ive done and used the thick washers that came with the kit both run ok all be it noisy when they do disengage.
Colin
  • nordom
14 Nov 2013 10:39 #91070 by nordom
Replied by nordom on topic Spartan locker strange noise
well, my solution was to take all washers away. now it works just fine: gently clicks during turns, engages and disengages smoothly. It clicks really harsh and loud while turning backwards and adding torque, but that's ok.
  • nordom
18 Nov 2013 08:25 #91807 by nordom
tested in the mud, works ok.
Disengages normally on road, locks and helps off the road.
the trail was tough, i've bended front wheel and arm (at least) and burned the automatic transmission.
Time to create page: 0.166 seconds
