AVM hubs - T15 Torx cone headed bolts
- Thank you received: 569
05 Jan 2023 14:21 #246682
Replied by DrRobin on topic AVM hubs - T15 Torx cone headed bolts
Thanks, good idea, I thought about using superglue, wasn't sure if it would work. It is just the broken Torx bit that needs to come out so that might work. I have plenty of small driver bits, so might try that first, with a bit of luck it will just pull the broken Torx bit out. If it doesn't work I can still drill it.
I did try a piece of rubber glued to the end of a bit and then press really hard, but it had a very small contact area and didn't get enough grip.
Robin
Robin
- Roger Fairclough
- Thank you received: 211
05 Jan 2023 15:33 #246683
by Roger Fairclough
Replied by Roger Fairclough on topic AVM hubs - T15 Torx cone headed bolts
I shouldn't have said drill bit, I should have said "bur". A drill bit will have difficulty in starting on what is probably a jagged piece of hardened steel especially as it is only 4mm in dia. Are you sure it is only a T15 Torx bit?
Roger
Roger
05 Jan 2023 15:52 #246685
It is definitely a T15, but it is not jagged, in fact rather smooth, so I stand a chance of superglue getting a firm hold, hopefully it will just pull the broken Torx bit out and then I can use a super hard hammer Torx bit I have bought.
I managed to shear it off in the first place as the recommended torque was right at the bottom end of my my torque wrench and I don't think it worked correctly. I have since bought another torque wrench to go down to 2NM.
The drill bits I have bought are made by Ruwag and feature a two step head, they have a small centre piece, then the main cutting head and can be used to self centre without punching first, see here
ruwag.co.uk/collections/metal-hss-drill-...riant=32729338347595
They are good value at under £2 for a small drill.
- Roger Fairclough
05 Jan 2023 17:25 #246688
by Roger Fairclough
It's HSS not tungsten so I wouldn't hold my breath, but good luck anyway.
Roger
Roger
05 Jan 2023 17:59 #246694
I know it doesn't say on the page, but I asked them if it was Tungsten Carbide tipped as I saw another page in the search which said they are. Apparently they are, it is just missed off the page for some reason.
I also bought a couple of Cobalt tipped drills, just in case.
- Thank you received: 688
05 Jan 2023 18:00 #246695
Replied by jackonlyjack on topic AVM hubs - T15 Torx cone headed bolts
My cheap hubs came with a couple of spares
I think they're m4
You will find they rust in
I use copper grease on the threads also cover the heads sort of fill the hole with waterproof grease
If Lambert can't help let me know if mine are same i'll post you one
I think they're m4
Time to create page: 0.702 seconds
