AVM hubs - T15 Torx cone headed bolts
  • DrRobin
  • Platinum Member
  • Platinum Member
  • Newbie in Northumberland
05 Jan 2023 10:00 #246673 by DrRobin
Hi,
When I put my AVM hubs on, I managed to break the end of a T15 Torx bit in one of the bolts, it is not in tight (they only go in to 4NM), but has resisted all atempts to get it out.  I am going to drill the centre of the Torx bit then just turn it anti-clockwise, it will come out, but I might damage the bolt and they don't seem to be available on their own.
Has anyone got a spare bolt they don't need?
I see I can buy a service kit that contains 12 bolts and the gaskets, so if it comes to it, I will buy one of those, then have some spares if anyone else needs one in the future.
Ta
Robin
05 Jan 2023 10:08 #246675 by Lambert
I'm at work just now but I think I might have one or two you can have. Let me check later this afternoon.
  • DrRobin
  • Platinum Member
  • Platinum Member
05 Jan 2023 11:07 #246677 by DrRobin
That would be excellent if you do have a spare, I will only need one, no rush.
Robin
05 Jan 2023 11:44 #246678 by Roger Fairclough
Isn't a Torx bit hardened steel? If it is you may need a tungsten carbide bit to drill your hole.
Roger
  • DrRobin
  • Platinum Member
  • Platinum Member
05 Jan 2023 11:52 #246680 by DrRobin
It is hardened steel and I have just purchased some tungsten carbide tipped drill bits to do the job, they were delivered this morning.
I suspect that the Torx bit will come out easily once drilled and a slight turn anti-clockwise as there is nothing holding it in other than the mating faces, then I should be able to get a new bit in and remove the bolt. If all goes well the bolt will come out with no damage and a replacement might not be required.
Robin
05 Jan 2023 12:09 #246681 by gv42
I USED SUPERGLUE ON THE TORX BIT
Time to create page: 2.518 seconds
