Low Idle Problem cant solve
  • Rorz18
20 Oct 2020 12:17 #229312 by Rorz18
Replied by Rorz18 on topic Low Idle Problem cant solve
Have you replaced the mass air flow censor
  • Gmichae5
21 Oct 2020 06:44 #229335 by Gmichae5
Replied by Gmichae5 on topic Low Idle Problem cant solve
Rorz18 No I havent replaced the map sensor. I cleaned it though.
I will though test it today with a scantool and see how it behaves.
  • nemesis505
22 Oct 2020 07:06 - 22 Oct 2020 07:07 #229380 by nemesis505
Replied by nemesis505 on topic Low Idle Problem cant solve
I. Have the same problem, but I haven't done anything yet, watching closely this thread. I have take aparte the iac and butterfly and carb clean everything. Didn't solve the problem.
2007 m13a
Last edit: 22 Oct 2020 07:07 by nemesis505.
  • Gmichae5
21 Mar 2021 18:35 #233886 by Gmichae5
For anyone that is still interested on this post problem solved. Changed the engine mounts and everything is ok now. Vibrating and low RPM gone. Everything runs smoothly. It is funny how 6 michanics checked the car and havent noticed that engine mounts needed to be changed.
Thanks everyone for help.
21 Mar 2021 21:24 #233894 by lightning
Well, give the mechanics a bit of sympathy, you wouldn't think that would cause the problem that you had.
l've never heard of tired engine mounts causing a low idle speed, although it was obviously the case here.
  • Owl
22 Mar 2021 06:33 #233900 by Owl
Replied by Owl on topic Low Idle Problem cant solve
Gday Gmichae5, I've just changed the fuel pump out and will give the vehicle a test run soon. Will report the outcome. Owl.
