Gen4 shocks replaced
19 Aug 2020 15:03 #226986 by Soeley
Replied by Soeley on topic Gen4 shocks replaced
I informed my insurance about my lift, that was it, no hassle and no increase in premium.
  • Grima
19 Aug 2020 16:05 #226989 by Grima
Replied by Grima on topic Gen4 shocks replaced
Churchill wants more money for a lift, what insurance are you using Soeley?.
19 Aug 2020 16:32 #226990 by Gadget
Replied by Gadget on topic Gen4 shocks replaced
lightning wrote: The Bilstein dampers are longer than the standard ones.
lf you fit them to a standard Jimny, is there any chance that the springs could dislocate?
On the Land Rover it's the dampers that limit suspension travel.
Dampers are always a compromise. l've played with aftermarket ones on my Defender and "upgraded" usually means "stiffer" which can be good for fast road use.
The trade off is a harder ride on poor surfaces.
Adjustable dampers are the way to go, then you can alter them depending on what you are doing in the vehicle.
One thing. The Bilsteins mentioned above are listed for Gen 3
Are they suitable for the new model?
From the Jimnystyle site (where they're listed as for the Gen4):
"The shock absorbers are also longer than the OEM (standard) items, allowing for a ride height increase when used in conjunction with longer springs. Alternatively, you can use them in conjunction with the OEM (standard) springs and enjoy an improved ride without lifting the suspension."
19 Aug 2020 16:38 #226991 by Lambert
Replied by Lambert on topic Gen4 shocks replaced
So they are basically the same as my 0 to 20mm trailmaster then? They will accept a slight increase in height or allow slightly more droop.
19 Aug 2020 17:09 #226993 by Soeley
Grima wrote: Churchill wants more money for a lift, what insurance are you using Soeley?.
LV, also declared front and rear recovery points and under-body protection and KC Daylighter spotlights. all at no extra charge.
  • Grima
19 Aug 2020 17:23 #226995 by Grima
Thanks Soeley, renewing in Nov. LV here i come.
Any idea on fitting a 30mm chain gun & hell fire missiles?
Time to create page: 1.176 seconds
