Gen4 shocks replaced
  • zebraman
18 Aug 2020 16:03 - 18 Aug 2020 16:04 #226914 by zebraman
Gen4 shocks replaced was created by zebraman
I bought some Bilstein shock absorbers from jimny style without the springs as I didn't need the car to be lifted and all the insurance issues it would bring plus I don't plan to go off-road.
They have just been fitted and I must say the car handles much better. It is much less bouncier and I have much more confidence on fast A roads. The car doesn't wobble as much when I shake it side to side and I don't need to really slow down for speed bumps.
For the people who are looking for the Jimny to handle a bit more like a road car I would certainly recommend the upgrade. It is also a bit cheaper than getting a lift kit fitted and you don't have to mess around with brake lines etc. Something tells me that any decent dampers will do the trick so you don't have to go with jimny style.
Happy to answer questions.
Last edit: 18 Aug 2020 16:04 by zebraman. Reason: Typo
  • CC Baxter
18 Aug 2020 16:29 #226917 by CC Baxter
Replied by CC Baxter on topic Gen4 shocks replaced
I've always been a fan of Bilsteins and here Jimny Style have done the work finding the right ones to fit. Good choice. Chris
  • GeorgeC
18 Aug 2020 18:17 - 18 Aug 2020 18:22 #226921 by GeorgeC
Replied by GeorgeC on topic Gen4 shocks replaced
zebraman wrote: I bought some Bilstein shock absorbers from Jimny Style without the springs as I didn't need the car to be lifted and all the insurance issues it would bring plus I don't plan to go off-road.
For the people who are looking for the Jimny to handle a bit more like a road car I would certainly recommend the upgrade. It is also a bit cheaper than getting a lift kit fitted and you don't have to mess around with brake lines etc. Something tells me that any decent dampers will do the trick so you don't have to go with Jimny Style.
You sound like a politician, ok, so here goes: May we have the Part Numbers please and a photo of them on the car?
Yesterday I drove on an old main road (Morley Drive,WA) and the suspension was terrible, I could easily isolate the feedback from the tyres compared with the shocks, the tyres are sweet, Lhs 22psi, Rhs22.5psi, No TPMS. :)
If I can find a set near the Service Department this morning, I may be able to drive home with them this afternoon! ;)
Last edit: 18 Aug 2020 18:22 by GeorgeC.
18 Aug 2020 18:21 - 18 Aug 2020 18:30 #226922 by lightning
Replied by lightning on topic Gen4 shocks replaced
This is interesting as l have found the suspension to be excellent on our new Jimny, the way it handles the poor road surfaces round here is remarkable considering the small size of the vehicle.
However l am always up for suggestions to improve it so would be willing to try the Bilstein dampers on the Jimny. But l am not sure what improvements l would be hoping for, perhaps the ideal would be adjustable dampers such as the 4-way adjustable ones l have on my Defender.
They can be set to soft for poor roads/off road use and progressively harder for "fast" road use if needed, which stops the Land Rover getting out of shape if it hits a pothole mid corner.
But l will say it again, l am impressed by the standard suspension on the Jimny, l wasn't expecting it to do so well on poor tarmac after reading various road tests where it was described as a "bucking bronco" on poor roads.
l would imagine it gets out of shape if you try to drive it like a GTi, but that's not going to happen with us. Although l might give it a go for a laugh and see what happens.
Last edit: 18 Aug 2020 18:30 by lightning.
18 Aug 2020 19:25 #226924 by saxj
Replied by saxj on topic Gen4 shocks replaced
lightning wrote: This is interesting as l have found the suspension to be excellent on our new Jimny, the way it handles the poor road surfaces round here is remarkable considering the small size of the vehicle.
The stock setup seems to be OK, until you have replaced it with some decent shocks and coils and realise how bad it actually was.
18 Aug 2020 20:03 #226932 by Lambert
Replied by Lambert on topic Gen4 shocks replaced
Having put time and effort into exploring the potential of a Jimny as a grip car for road and track I would suggest that any money spent on upmarket dampers is money well spent. For anything more than pottering about well below the speed limit the standard dampers are simply too slow witted. They just don't offer enough control for rapid direction change on irregular surfaces like the common British country back road with the expected result of making the car feel nervous and the driver back off. However the Jimny is actually a very capable chassis for tight twisted roads if you give it the benefit of some higher quality dampers that work properly even when you are working them hard.
The following user(s) said Thank You: saxj
Time to create page: 6.248 seconds
