2 questions - AC parts and lockers
  • CC Baxter
09 Aug 2020 08:15 #226376 by CC Baxter
Replied by CC Baxter on topic 2 questions - AC parts and lockers
With all this talk of diffs (quite exciting) I missed your question on aircon parts.
High and low side valves can in theory be optained from any AC specialist (like office block installation people) but you will need the correct pressure specifiations. If you manage to get those you will then have to make brackets to mount them and then pay for pump down/recharge.
In my view not worth it. A pair of valves from the breakers yard (from as newer model as possible) sounds much more tempting. Talk to an auto AC specialist and see what they can offer. Chris
09 Aug 2020 14:34 #226399 by me101
Sniper - it is more to overcome cross axle situations, so I think that makes my mind up. Thanks.
CC Baxter - The breakers might be a good idea, I thought I would have to get new ones. Cheers.
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
09 Aug 2020 16:02 #226408 by Roger Fairclough
I had a gear style limited slip diff on my Landcruiser that transmitted about 85% torque when pushed and yes it was very useful on even dry twisty roads but if you are after control on axle twisters then "left foot braking " may be your answer, especially as it's completely free.
The technique goes like this. You are cross axled, opposite wheels are in a trough and spinning uselessly.You transfer your left foot to the footbrake and apply pressure whilst gradually increasing power. The braking effort splits equally between the rear brakes and traction is restored and out you pop.
Does it work-oh yes. If it sounds familiar it's what traction control is all about. Once you are out of the hole, feet off everything to let the motor settle and then away you go.
Roger
09 Aug 2020 19:47 #226424 by me101
I know about left foot braking (not great at it!), and if my diff wasn't in need of replacement, I would not be parting with my cash. But, not wanting to put a 2nd hand standard diff in when I have the option to go better. (Well, it is an option as long as she doesn't know!!)
10 Aug 2020 07:39 #226442 by maverick
I have a set of Kaisers (front and Rear) www.jimnybits.com/jimny/drivetrain/suzuk...ocker-by-kaiser.html
I used to run a Detroit Lockrite in Rear Diffential, but they just chew the enfeds off your shafts and bugeer uo your Diff.
Think of a Kaiser as a poor mans ARB.
Jalapeño, IISY?
10 Aug 2020 09:11 #226447 by Roger Fairclough
The Detroit Lockrite was locked for normal straight line driving and unlocked when you went round bends. The small print mentioned that driving habits would need to accommodate it's somewhat strange behaviour. Due to the way it unlocked and then locked back excessive wear was possible.
Just my opinion.
Roger
Time to create page: 3.792 seconds
