2 questions - AC parts and lockers
10 Aug 2020 10:35 #226448 by me101
Right, thanks for your input guys, but been to garage today to pick it up out of their way for a bit. We have discussed the idea of the locking diff, and it sounds like I need a couple of other bits, and with the cost of swapping it out (plus the initial cost of the part) I just can't do it. So, my new question is, how much should I be paying for a replacement back axle? Cheers
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
10 Aug 2020 11:26 #226451 by Roger Fairclough
What is it they they say you need and how much are they quoting you to do the work? I know this may sound nosey but it would help us to help you.
Roger
10 Aug 2020 11:39 #226452 by me101
To be fair, I didn't fully understand everything, and they said they would not do the work in house anyway, they would get the work done elsewhere. They didn't sound keen on the set up of it but said the locker itself would not get rid of the noise I have on the rear end. Didn't get a price, they are very good with me, used them for years, they have basically talked me into an axle swap which financially is better for me really.
10 Aug 2020 11:59 #226453 by sniper
M & T Transmissions in Sheffield fitted my ATB for £200 if that is any help....
You should be able to find a full axle secondhand, j999pre is member on the forum who breaks the odd car and sells new/used parts, send him a private message.
sniper
10 Aug 2020 12:05 #226454 by me101
Cheers Sniper
10 Aug 2020 13:48 #226458 by Roger Fairclough
The differential consists of the pinion, which transmits power from the engine, and the crown wheel which is bolted to the diff. casing. If you are replacing the standard diff. with an aftermarket one then you should not need to disturb the pinion unless the bearings are shot and as your guy said that fitting a new diff. would not cure the noise then i suspect he believes it may be the pinion bearings. Most modern diffs. rely on crush spacers to set the preload and most garages farm out this work as fitters don't know how to do it.I replaced the crush tube on my Landcruiser with a solid tube sourced from the states.If you can get a s/hand axle from a reliable source that is probably the way to go.
Roger
Time to create page: 0.193 seconds
