Gen3 v Gen4 performance?
- CC Baxter
19 Jul 2020 18:56 #225337
by CC Baxter
Replied by CC Baxter on topic Gen3 v Gen4 performance?
We've got a Gen3 and Gen4 at home and when you jump from one to another it's hard to tell the difference. The older car rattles more and the newer car is smoother (it bloomin' well should be). If I had a late Gen3 it would be a fairer comparison but out '08 has seen life. I feels to me that the extra power of the 1.5 has got lost in the plumbing. Doesn't matter they're both good cars. Chris
- Thank you received: 1876
19 Jul 2020 19:42 #225345
Replied by Lambert on topic Gen3 v Gen4 performance?
Any Jimny will not come alive much below 3000 rippems, they are small petrol engines and need revs to make torque. They are not a diesel that is running out of revs at 3500 rpm. We used to have a mk1 terrios and while it was much the same character the Jimny is a better choice, the torque is much wider in the range.
The following user(s) said Thank You: Foxtrot
19 Jul 2020 20:09 #225353
by lightning
Replied by lightning on topic Gen3 v Gen4 performance?
I’ve driven two Gen 4 Jimnys.
The first last year was a 1,300 mile silver one and it felt a bit gutless, l wasn’t that impressed.
The second was a 6,300 mile yellow one this month and it was a lot better, it seemed more eager and generally pulled better.
Maybe the yellow one was just a good one, or it had loosened up better after 6,000 miles.
19 Jul 2020 22:25 - 19 Jul 2020 22:26 #225371
by 300bhpton
Replied by 300bhpton on topic Gen3 v Gen4 performance?
Another thing. I was impressed with how well they pull low down. 30mph in 5th for instance. And will pull sub 1500rpm in top too.
Flat out the Jimny pretty much matches my V8 Range Rover to about 80-85mph.
Last edit: 19 Jul 2020 22:26 by 300bhpton.
- Roger Fairclough
- Thank you received: 211
20 Jul 2020 21:26 #225406
by Roger Fairclough
Replied by Roger Fairclough on topic Gen3 v Gen4 performance?
The 1.3 12 valve Starlet engine comes from the Toyota stable and if it has been grafted into a Terios then it may or may not be standard. Also don't confuse a probably noisy engine that gives the impression of power with the installation of a modern engine in the gen.4 that is impressively quiet. I bought my gen.4 in March this year and due to lockdown I have only just clocked 1300 miles and the engine is still not fully run in but 50 - 70 in 5th gear in 13 seconds is still impressive for a car with the aerodynamics of a brick on edge.
21 Jul 2020 07:22 #225413
by Busta
Replied by Busta on topic Gen3 v Gen4 performance?
You can't change gear at 3,000rpm and then complain the car is slow! It's a small petrol engine that makes peak power at around 6,000rpm, and it is designed to be driven accordingly. If you choose to only use a third of the available powerband of course it will be slow. Use it how it's designed to be used and it will be fine.
The following user(s) said Thank You: lightning
Time to create page: 0.969 seconds
