Gen3 v Gen4 performance?
- Thank you received: 1875
Reason2doubt wrote:
Busta wrote: You can't change gear at 3,000rpm and then complain the car is slow! It's a small petrol engine that makes peak power at around 6,000rpm, and it is designed to be driven accordingly. If you choose to only use a third of the available powerband of course it will be slow. Use it how it's designed to be used and it will be fine.
Take Busta's advice and just rev the nuts off it all the time. Sounds like solid advice for daily driving a Jimny... :lol: :lol:
I have been working on the same assumption as Busta for a hundred and five thousand miles. When they were inside the motor with the head gasket they said it looked virtually like new inside the cylinder bores.
- Grima
I think that was the speed limiter as it wouldn’t go any more than that. A shame the speedo seems to still be 3-4mph out at 60 and 70mph though
Fitting 215/75 tyres put my speedo bang on until I changed the diffs, but the standard gen3 205/70 are slightly smaller than the 195/80 on the gen4 so that correlates with your findings.
I put a 1.6 in my previous Jimny and that was better, probably on a par with a gen4.
300bhpton wrote: Well while I’m certain the new AT’s have blunted the performance a bit. I did manage to see 100mph on the speedo (private road). Which according to GPS was 96.3mph.
I think that was the speed limiter as it wouldn’t go any more than that. A shame the speedo seems to still be 3-4mph out at 60 and 70mph thoughI thought the 215/75’s would have had more impact in correcting it.
I got mine up to 150kph when it was new, and then it tried to kill me. It developed a very disconcerting side to side wobble, so I never tried that again. Now it's lifted with 235's so absolute max is 140kph. The new shocks make it a lot more stable.
