First Time Jimny Owner
- AngusChap
22 Feb 2020 08:28 #218866
by AngusChap
Replied by AngusChap on topic First Time Jimny Owner
Thanks, that’s a great site! Some quality of work there.
I think you’re right, there’s no rush to use it so probably getting off as many of the panels as possible and going right over it will be a good start. Just in case there is anything gently rotting away out of sight...
Will have a good rake through the site for any other potential problem areas
22 Feb 2020 09:02 - 22 Feb 2020 09:03 #218867
by Scimike
Replied by Scimike on topic First Time Jimny Owner
Hello and Welcome along.
I would remove any loose underseal and sand back any accessible rust areas. Treat with a rust converter and over paint with a direct to rust paint. Re-apply stone chip to any areas you removed, then wax inside and out, cover everything.
People will have their preferred products for this, as do I, but it's a can of worms as to which is best.
Ours is a 2009 low milage example and pretty good underneath before I did the above , it's worth removing the front bumper and inner arch skirts to the a look at the front body mounts, one side on ours required a welded repair at 10 years old. Now done and dripping in wax.
Have fun.
Mike
Ps I also like buzzweld paint.
Have fun.
Mike
Last edit: 22 Feb 2020 09:03 by Scimike.
- Thank you received: 1875
22 Feb 2020 09:47 #218871
Replied by Lambert on topic First Time Jimny Owner
Welcome to the forum. I use Dreadnaught in much the same manner as a sensible alternative to a side by side on our upper lowland sheep farm, you will not be disappointed!
22 Feb 2020 12:07 - 22 Feb 2020 12:10 #218882
by Scimike
If you do go for bumper / arch liner removal it's worth getting some clips ready for the odd one that breaks. Cheap as chips so why re-use old faulty ones?
www.ebay.co.uk/p/14007670614?iid=1633197...jNoi8tQaAh2iEALw_wcB
Sorry about the long link, never figured out how to do the short one.
Also used on Fiats if you want UK supply, search for Fiat bumper clip.
Code:
Last edit: 22 Feb 2020 12:10 by Scimike.
- Thank you received: 683
22 Feb 2020 12:49 #218883
Replied by jackonlyjack on topic First Time Jimny Owner
No eBay APP ID and/or Cert ID defined in Kunena configurationThose clips in link above will only fit certain places
for retaining arches ect you will need these
(these fit perfect ignore the toyota bit OR pay double for suzuki ones)
Jack
Jack
- Max Headroom
- Banned
- Thank you received: 217
22 Feb 2020 16:48 #218889
by Max Headroom
Replied by Max Headroom on topic First Time Jimny Owner
A BIGJimny welcome to you from the Cotswold Hills - you'll find lots of good info here, Angus!
Time to create page: 2.374 seconds
