Re:Suzuki Jimny 2007 problem 4WD
  • Cvejic
07 Jan 2020 08:28 #217077 by Cvejic
Replied by Cvejic on topic Re:Suzuki Jimny 2007 problem 4WD
Is there any other part, spring or something?
07 Jan 2020 13:37 #217081 by facade
Presumably, the ball is to stop the peg of the switch getting chopped off.
On the lever transfer, the switch only switches when the ball drops into the detent on the shaft, which is only when fully in 2WD. All the rest of the time the ball presses the switch and keeps it pushed. Remove the ball, and the switch will be not pressed all the time and the transfer will never figure out it is in 4WD.
I assume the electric transfer is similar.
As disconnecting the switch gets 2WD, I'm guessing that pressing the switch turns it OFF, and it turns ON when the ball falls in the detent.
It can never work properly without the ball to add the "extra press"
The following user(s) said Thank You: Cvejic
  • Cvejic
07 Jan 2020 15:01 #217084 by Cvejic
First I have to unplug the 4wd switch and then by pressing 2wd in the cabin I go to the rear drive. To get back in ( 4wd hi ) I need to plug in a 4wd switch. (4wd lo) cannot be included. To mention that I Suzuki Jimny bought with a faulty 4wd system. When mounting new 4wd switch I successfully switched from 2wd to (4wd hi and 4wd lo) and successfully returned to 2wd. After 10 minutes I tried again and I got this problem.
07 Jan 2020 15:12 #217085 by DrRobin
I had a similar problem on New Year's Eve in a 2011 Jimny. I had to use 4WD to reverse up a bank on rough ground to watch the fireworks. I then tied to put it back in to 2WD and the 4WD light just flashed.
It would select 4WD or 4WD-L but not 2WD. I switched the engine off, waited 10 seconds and put it back on, it then switched back in to 2WD and seems to have been fine since. It works fine in all 3 modes, just that one off selection problem.
07 Jan 2020 15:20 #217086 by DrRobin
Just two other thoughts....
When I first tried to switch out of 4WD to 2WD I was on a hill, facing downwards; and
I was probably also still in reverse with the clutch in.
Would the hill or in reverse cause a problem? I saw the comments about the 'ball' dropping in to place.
I probably put it in to neutral, but can't quite remember the sequence. All I know is I couldn't shift back in to 2WD until after cutting the ignition.
  • Cvejic
09 Jan 2020 21:36 - 09 Jan 2020 21:38 #217134 by Cvejic
I'm still without a solution. I checked ball bearing and it's okay. The figure shows that there is a spring, what is the role of the spring and in what position should the switch be held? Did anyone have a problem with the spring?
The part bears number 14
Last edit: 09 Jan 2020 21:38 by Cvejic.
Time to create page: 2.058 seconds
