Re:Suzuki Jimny 2007 problem 4WD
- Cvejic
04 Jan 2020 18:27 #216998
by Cvejic
Suzuki Jimny 2007 problem 4WD was created by Cvejic
Hello everyone,
my problem is that my jimny remains stuck in 4wd hi, the bulb on the board turns on and off at 1 second intervals.
It stays so stuck and 4wd works and cannot return to 2wd. To get back to 2wd I need to unplug the 4wd switch and by pushing the cabin to 2wd it turns off 4wd. Without unplugging 4wd switch, it is not possible to 2wd.
What is the problem?
- Thank you received: 1876
05 Jan 2020 05:33 #217011
Replied by Lambert on topic Suzuki Jimny 2007 problem 4WD
Welcome to the forum. By the sound of it this is an electrical problem and the easiest thing to do first is check the condition of the wires coming from the transfer box for obvious damage or bad contacts.
The following user(s) said Thank You: Cvejic
- Cvejic
05 Jan 2020 18:36 #217027
by Cvejic
Replied by Cvejic on topic Suzuki Jimny 2007 problem 4WD
05 Jan 2020 20:06 - 05 Jan 2020 20:06 #217028
Replied by mlines on topic Re:Suzuki Jimny 2007 problem 4WD
Is it really once per second for the flashing? The computer on the electronic version flashes twice per second or five times per second.
See the wiki for details.
www.bigjimny.com/mediawiki/index.php?tit...ion_system_operation
Last edit: 05 Jan 2020 20:06 by mlines.
- Cvejic
06 Jan 2020 21:49 #217074
by Cvejic
Replied by Cvejic on topic Re:Suzuki Jimny 2007 problem 4WD
At me then it flashes twice a second, I did not measure accurately. To mention, no matter what it is flashing light 4wd works, the problem arises at shutdown 4wd. The 4wd switch made the joint, so i'm interested in what the role of the ball bearing is and if there can be a problem in it?
07 Jan 2020 05:01 #217075
Replied by Lambert on topic Re:Suzuki Jimny 2007 problem 4WD
The ball is effectively acting as a detent to provide correct location for the switch to work against.
Time to create page: 0.195 seconds
