On Board Air
- Thank you received: 498
Viair 400c with the 2.5 gl tank, will it fit under the frame? Or smaller system?
Or just to buy an arb single compressor, or something else?
I read here and there for days but still confused as to what is smart...
- Thank you received: 1869
Lambert wrote: I knew a bloke who not having air conditioning on his land rover fitted an ac compressor and used that instead of a very expensive arb one and he reckoned that it could run simple tools as well as his diffs. Might be worthwhile looking at?
So many good electric solutions around i think those would suffice for me.
I want to keep my AC
If I were to go down that route I would probably try to use the PTO to power hydraulic winch and compressor. But that would be the other car.
I have looked at yours Martin,. but have you tried to fit that tank under the car?mlines wrote: I have a Viair system with a small compressor. It does the ARB locker and can inflate the tyres and run small tools
I do not want it inside..
Rust will kill it I know, but do you know if there is room?
Might have to re-route the exhaust a bit then maybe?
I have a few oxygen tanks from the ambulance I could use as a high pressure powertank or for a smaller low pressure air tank(s) below the car.
They are smaller and could probably fit inside as well. But they are heavier than the Viair tank i guess..
Like a small fire extinguisher.
You could source a small lorry/van cylinder if you wanted something of exterior quality
