On Board Air
10 Dec 2019 21:44 #216374 by yakuza
On Board Air was created by yakuza
So my new ARB needs air.
Viair 400c with the 2.5 gl tank, will it fit under the frame? Or smaller system?
Or just to buy an arb single compressor, or something else?
I read here and there for days but still confused as to what is smart... :)
11 Dec 2019 05:15 #216376 by Lambert
Replied by Lambert on topic On Board Air
I knew a bloke who not having air conditioning on his land rover fitted an ac compressor and used that instead of a very expensive arb one and he reckoned that it could run simple tools as well as his diffs. Might be worthwhile looking at?
11 Dec 2019 06:49 #216377 by mlines
Replied by mlines on topic Re:On Board Air
I have a Viair system with a small compressor. It does the ARB locker and can inflate the tyres and run small tools
11 Dec 2019 07:15 #216379 by yakuza
Replied by yakuza on topic On Board Air
Lambert wrote: I knew a bloke who not having air conditioning on his land rover fitted an ac compressor and used that instead of a very expensive arb one and he reckoned that it could run simple tools as well as his diffs. Might be worthwhile looking at?
So many good electric solutions around i think those would suffice for me.
I want to keep my AC :)
If I were to go down that route I would probably try to use the PTO to power hydraulic winch and compressor. But that would be the other car. :)
11 Dec 2019 07:21 #216380 by yakuza
Replied by yakuza on topic Re:On Board Air
mlines wrote: I have a Viair system with a small compressor. It does the ARB locker and can inflate the tyres and run small tools
I have looked at yours Martin,. but have you tried to fit that tank under the car?
I do not want it inside..
Rust will kill it I know, but do you know if there is room?
Might have to re-route the exhaust a bit then maybe?
I have a few oxygen tanks from the ambulance I could use as a high pressure powertank or for a smaller low pressure air tank(s) below the car.
They are smaller and could probably fit inside as well. But they are heavier than the Viair tank i guess..
Like a small fire extinguisher.
11 Dec 2019 07:25 #216381 by mlines
I have never looked to see to be honest. It would rust out pretty quickly as it is thin metal.
You could source a small lorry/van cylinder if you wanted something of exterior quality
