Scratch head (Gen 4 Owner manual)
  • Andy2640
03 May 2019 06:59 #207178 by Andy2640
Replied by Andy2640 on topic Re:Scratch head (Gen 4 Owner manual)
Lambert wrote: Mine didn't make it to year 4. Since then I have had avm manual ones. Bit more effort but way more reliable and versatile. They allow me to run on the road in 4x2lo which is great for towing and manoeuvring trailers. It is possible to do this electronically on the gen3 as well as mechanically so I suspect that it is a modification in development for the gen4.
Ohh, that dont sound too promising. Even with regular servicing they can still go awry? Damn it. I'll be keeping an eye out for that mod then.
Cheers
03 May 2019 07:09 #207181 by Lambert
On the gen3 there are two failure modes. The solenoid packs that control the vacuum to the hubs can get full of debris and need cleaning if you are lucky or die a miserable death if you are not. And on older cars the vacuum pipes on the axle corrode and leak. They are replaceable but most people will bypass them and either lock the hubs permanently or fit manual ones like I have. Either way not a big deal to sort.
The following user(s) said Thank You: Andy2640
03 May 2019 07:23 #207182 by Bob1050
The section on jacking the Jimny up using a trolley jack (e.g. to change a wheel) is a tad ambiguous. Read the words and look at the diagram - can you put the jack under the axle/diff and lift or not? How should you do it - bet your average garage or tyre depot operative won't be following the Manual..
As for the guidance on changing between 2 & 4 WD and LR and HR - downright confusing.
03 May 2019 07:35 #207184 by Lambert
On th gen3 radius and trailing arms there's little nub things cast into the bottom edges about half way along. They act as locating pins to stop the pad of the jack from slipping. I only put stands under the actual axle and as close to the spring seats as I can.
  • AlexK
03 May 2019 07:57 #207186 by AlexK
Replied by AlexK on topic Scratch head (Gen 4 Owner manual)
The manual was perhaps trying to say don't shift into 4H while depressing the accelerator. If you release the gas pedal it will reduce the load in the drivetrain making it easier for the transfer case to engage the front axle.
  • Andy2640
03 May 2019 08:10 - 03 May 2019 08:11 #207188 by Andy2640
Bob1050 wrote: The section on jacking the Jimny up using a trolley jack (e.g. to change a wheel) is a tad ambiguous. Read the words and look at the diagram - can you put the jack under the axle/diff and lift or not? How should you do it - bet your average garage or tyre depot operative won't be following the Manual..
Thats a good point.
My tyre fitter, jacked it up from around the axle, couldnt see exactly where, as i was sneeky peeking them from a distance. Needless to say i was worried.
Last edit: 03 May 2019 08:11 by Andy2640.
Time to create page: 0.227 seconds
