Scratch head (Gen 4 Owner manual)
  • Andy2640
03 May 2019 05:35 #207152 by Andy2640
Scratch head (Gen 4 Owner manual) was created by Andy2640
Morning all,
On page 3-16, the topic is "changing from 2H to 4H" - Its states "Do not shift the transfer lever without depressing the accelerator pedal" EHH????
It also goes on to say that the locking air hubs cannot be activated if the vehicle is slowing down, but then says it can be done at standstill. EHH?
Any help would be appreciated.
  • stiffsteve204me
03 May 2019 05:58 #207159 by stiffsteve204me
Replied by stiffsteve204me on topic Scratch head (Gen 4 Owner manual)
The first part, I would assume, is a misprint, Andy. Surely, it should read brake pedal?:huh:
Where are you seeing this?:
"It also goes on to say that the locking air hubs cannot be activated if the vehicle is slowing down, but then says it can be done at standstill."
Full marks to you for reading the manual, by the way. :laugh:
Steve.
  • Andy2640
03 May 2019 06:07 - 03 May 2019 06:08 #207161 by Andy2640
Replied by Andy2640 on topic Scratch head (Gen 4 Owner manual)
stiffsteve204me wrote: The first part, I would assume, is a misprint, Andy. Surely, it should read brake pedal?:huh:
Hhaha, thanks Steve. All this is on page - 3-16.
It makes me laugh, because next to most this 4H to 4L thing, there are warnings saying "FAILURE TO FOLLOW WILL RESULT IN SERIOUS MALFUNCTION" Intimidating bloody manual so it is ;-)
Ok, the manual actually says this; " The air locking hubs are activated by the vacuum of the engine and changed to shift the front wheel drive. The air locking hubs are not shifted when the engine is stopping" / - So are they saying that decelerating will not activate the air hubs? Hence there instruction to be accelerating??
Mhhhhhh Pondering's..........
Steve.
Last edit: 03 May 2019 06:08 by Andy2640.
  • stiffsteve204me
03 May 2019 06:23 #207167 by stiffsteve204me
Steve.
Ah! Now, I read that as saying that the engine needs to be running for the air hubs to operate.
I think that it should read "The air locking hubs are not shifted when the engine is stopped"
Steve.
03 May 2019 06:26 #207169 by Lambert
I think it means that the engine has to be running to generate the vacuum. So it won't activate the hubs when switched off. I would also expect that charging between ratios is done while stationary and the brake applied and clutch down. But it should be able to switch from 4x2 and 4x4 high on the move.
The following user(s) said Thank You: Andy2640
03 May 2019 06:27 #207170 by Bill Portland
The translation of the manual is quite good, but I noticed it get worse further on.
Time to create page: 1.010 seconds
