Wheels and tyres
- Cremator1
17 Jan 2019 18:51 - 17 Jan 2019 18:52 #200997
by Cremator1
Replied by Cremator1 on topic Wheels and tyres
Ok guys so we no it is 60 degree so I should be ok with the nuts that held my alloys on as they are 60 degree
Last edit: 17 Jan 2019 18:52 by Cremator1.
17 Jan 2019 18:58 #200998
Replied by jackonlyjack on topic Wheels and tyres
Yes and just to be sure if you remove one nut and look at the wheel you should be able to see where the nuts marked the paint
also paint may have transferred onto the nut should be a mark around 2.5mm from the nut face
17 Jan 2019 19:08 - 17 Jan 2019 19:17 #200999
Replied by Riccy on topic Wheels and tyres
Put it this way...
If the wheels are staying on and you haven't got any wheel wobble they are working
Fitting nuts that are wrong will bugger up the wheel balance and possibly damage the wheel. Driving at low speeds wouldn't be noticed, but get up to 65-70mph and it will be shaking worse than Elvis.
A easy test, to be certain, would be to take a wheel off and try sitting a wheel nut in one of the holes. if it fits snug then and doesn't wobble about easily then all is well, if its slipping around and not matching the shape of the hole, it is wrong. Nice simple test
Last edit: 17 Jan 2019 19:17 by Riccy.
- Cremator1
17 Jan 2019 19:12 - 17 Jan 2019 19:12 #201001
by Cremator1
Hi Riccy ok I will try that tomorrow but I am sure they sit in the hole fine
Last edit: 17 Jan 2019 19:12 by Cremator1.
- Thank you received: 1983
17 Jan 2019 19:26 #201004
Replied by Lambert on topic Wheels and tyres
So what, if you're happy with the nuts sitting in the holes, is actually causing you concern?
- Cremator1
17 Jan 2019 20:00 #201008
by Cremator1
I asked if my alloy wheel nuts would be ok with these wheels and was told I needed steel wheel nuts for them
Time to create page: 0.222 seconds
